Brake adjustment
Old Aug 1, 2024 | 02:43 PM
Tobey Anderson's Avatar
Tobey Anderson
4wd High
Brake adjustment
So I have a 1987 f250 That I put super duty axles under and I have experienced more breaking power in the back tires i cant spin the back tires while trying to do a burnout I know that could also be a power in the truck issue but I was wondering if there was any adjustments I could make in the frame rail or on the brake line with a adjustable valve. Any help would be greatly appreciated.
Old Aug 1, 2024 | 03:44 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Breaking power? What did broke? Sorry. Couldn’t help myself.
You had disk/ drum brakes and now have disk/disk? That’s your problem.
Old Aug 1, 2024 | 09:37 PM
Tobey Anderson
4wd High
So I put superduty axles into my truck and I feel like it has more breaking pressure in the back and I'm not sure if their is a factory valve I can adjust to even put the pressure
Old Aug 2, 2024 | 04:42 AM
My4Fordtrucks
That’s what you said the first time. The system is set up for drums but now you have disk brakes on the rear which is why you have so much braking from the rear. No. There is no valve to adjust.
Old Aug 2, 2024 | 06:10 AM
tjc transport's Avatar
tjc transport
i ain't rite
no valve in the truck now to adjust rear brake pressure. what you need is an add on adjustable proportioning valve to put at the master cylinder. this will let you decrease pressure to the rear brakes to equalize them.
Old Aug 2, 2024 | 08:18 AM
FuzzFace2's Avatar
FuzzFace2
Are you still using the disc / drum master of did you swap in the SD disc / disc master?
If still running the old master there is a valve in it to the drum side that held a little psi to over come the drum brake springs.
This valve needs to be removed. Pull the flare seat out of the master and behind it should find a spring and a valve / seat.
Remove the spring and valve / seat and put the flare seat back in you should be all set.
Just note disc take more fluid and the old master dose not have a lot now for the rear disc.
Dave ----
JAhearne
Dec 29, 2017 02:51 PM
Cracker289
Jun 11, 2015 05:49 AM
chriskot
Apr 1, 2009 08:19 AM
hammerdn
Feb 24, 2003 12:19 AM
jor
Feb 11, 2002 09:24 PM
