brake part name ?
Old Feb 20, 2003 | 07:41 PM
hammerdn's Avatar
hammerdn
Question brake part name ?
I need to know the name of this part I need, could any one help. This part is located under driver side door bolted inside the frame on a 77 F-150 4x4. the brake lines come from the master cylinder into it and then go out of it to the back I think. it kindda looks like a large slave cylinder for brakes or something (although I dont think it is a slave cyln). it has 4 brake lines hooked to it and a power supply. any ideas. THANKS
Old Feb 20, 2003 | 07:57 PM
DPW's Avatar
DPW
brake part name ?
Proportioning valve, controls the amount of brake pressure going to front and rear.
Old Feb 20, 2003 | 08:15 PM
hammerdn's Avatar
hammerdn
brake part name ?
thanks
Old Feb 21, 2003 | 02:12 AM
Torque1st's Avatar
Torque1st
Posting Legend
brake part name ?
If the part has another branch to the casting almost opposite the "power supply" it is a proportioning valve, if it does not have that extra branch it is a differential metering valve.
The "power supply" is a switch that activates your brake failure light. If a rear brake hose blows the differential valve spool shifts and seals off the rear brake system and activates the switch. If a front brake line fails it seals off the front brakes etc.
The proportioning valve unit does the same light activation, seal-off, and also reduces the pressure to the rear brakes to help avoid rear brake lockup.
Old Feb 21, 2003 | 02:23 PM
dfisher1's Avatar
dfisher1
brake part name ?
Eric,
Are you sure?
I'm sure that's where the power comes from for the "Power Brakes"?
LOL
KingFisher
Old Feb 22, 2003 | 05:14 AM
Torque1st's Avatar
Torque1st
Posting Legend
brake part name ?
Only if it has the orange fusible link to the battery with the diode to prevent feedback!
Old Feb 24, 2003 | 12:13 AM
Purely Ford's Avatar
Purely Ford
brake part name ?
Just curious, but how is it possible to bleed a brake system if the differential metering valve can shut off front or rear brake system that has a blown brake line? Bleeding brake system should create the same condition shouldn't it?
Old Feb 24, 2003 | 12:19 AM
Torque1st's Avatar
Torque1st
Posting Legend
brake part name ?
Yes it can and that is what messes up a lot of brake systems. That is why I recommend a vacuum brake bleeder to bleed the brakes. Many people push on the brakes b4 the bleeder valve is released which can add to the problem.
