Help...
Old Jul 30, 2024 | 10:34 AM
Bob2246's Avatar
Bob2246
Originally Posted by 52 Merc
There's been a lot of talk about length of dipstick, but that's only half of the equation. What's the length of the dip stick tube? If the tube is too short, even if the stick is correct, the stick will go down too far and read full before you're full.
Originally Posted by 52 USCG Panel
As you can see, there is just a bit of a tube for the dipstick right next the oil filter canister. It measures only about 7/8's of an inch. The dipstick extends just a bit more than 8 1/2 inches into the engine.
Thanks 52 Merc and 52 USCG Panel, you cleared things up. I drained the oil, and put it back a quart at a time, each time measuring the witness left on the dip stick. 3 quarts puts me at the FULL mark. 5 quarts puts me an inch (ish) higher. With the tube (that I don't have), I'd be right at the FULL at 5 quarts.
Originally Posted by bmoran4
That tube has traces through my Ford part books under various part numbers and falls out of Ford's documentation in the mid-late 80s.:
9N-6754
9N-7020
B8A-6754-B
Roughly described as an Oil Level Indicator Tube with a .375" OD and a length of 1.420"
A commercial source: https://fixthatford.com/oil-indicator-tube-9n7020.html
bmoran4, thanks for the lead on the tube, but it turns out that it is no longer available. I guess I'll either have to troll swap meets, of fashion one out of tubing.
The scary part for me is that this truck has been running on 2, maybe three quarts of oil tops for years I'm guessing. The oil pressure has been ok, about a third of the way up the scale on the factory gauge. When I filled it blindly (5 quarts), the pressure rose to half scale, or 30 psi, according to the same gauge. I suspect that having a full reservoir made for improved oil delivery. That coupled with, I'm guessing, sludge buildup in the oil passages in the head are the cause of the blue smoke that I now see; I'm thinking that more oil is getting to the top faster, and can't drain fast enough, so it is leaking past the valve bushings into the cylinders. I plan to run some SeaFoam through it, change the oil again, and hopefully this will solve the smoke problem. At least I know for certain that it isn't being overfilled.
Thank you all so much for your time and helpful suggestions.
See you on the forum.
Bob
Old Jul 30, 2024 | 11:51 AM
badger_hound's Avatar
badger_hound
The traditional wisdom I've always gone by is that it is better to be a little low on oil than overfilled. I can see why it would have run fine on 2-3 quarts at about 15-20 psi in the past if it wasn't pushed hard, that said, you may be looking at more wear on your drive train as a consequence. What I don't get is why when you fill it to 5 quarts, which should be correct regardless of your dipstick issues and slightly dented oil pan, you get a bunch of blue smoke. Particularly when your oil pressure is at 30 psi, which is in the normal range (20-30 psi). Your idea that residual sludge in the head is causing the smoke seems reasonable. If the Seafoam doesn't work, I guess the nest step is to perhaps pull it to inspect the oil passages in the head and top of the block?
Old Jul 30, 2024 | 12:43 PM
Bob2246's Avatar
Bob2246
I was (reluctantly) preparing to at least remove the top valve cover, then thought of SeaFoam. I figured it couldn't hurt to try, the stuffs been around forever.
Fingers crossed.
Thanks
Old Jul 30, 2024 | 01:31 PM
badger_hound
It's definitely worthwhile, regardless of the Seafoam treatment. Valve cover gaskets are cheap, and you'll definitely get a better idea of whether you need to pull the head.
Old Jul 30, 2024 | 08:50 PM
52 Merc's Avatar
52 Merc
Without a dip stick tube, the stick is just flopping around and isn't even sealing. Here's the tube you need. My old catalog says this is the right part not only for N tractors, but for 226, 254, 215 and 223 6 cylinders from 48-55, which is the coverage of my catalog.
Old Jul 30, 2024 | 08:59 PM
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
Is there an echo in here?
9N-6754
9N-7020
B8A-6754-B
CascadeF250
Feb 28, 2023 09:34 PM
jake415
2015 - 2020 F150
Jun 18, 2021 05:40 PM
hikeril
6.7L Power Stroke Diesel
22
Feb 27, 2012 11:14 PM
cps
Jul 19, 2008 05:19 PM
texas_vet
Feb 20, 2006 10:40 AM
