“Trailer Disconnected” when I shift into reverse
Old Jul 27, 2024 | 03:35 PM
Reverend Jim's Avatar
Reverend Jim
Veteran: Navy
Exclamation “Trailer Disconnected” when I shift into reverse
As the title says, when towing my trailer, as soon as I shift into reverse I immediately get the warning chime and message on the dash. As soon as I put it back in drive, all is good again. I’ve searched and didn’t see anyone else have this issue. I’ve replaced the bumper plug connector and packed it on both sides with dielectric grease, but it didn’t make any difference. The trailer does have reverse lights, (14’ dump trailer, all LED lights). I know how picky these new trucks are with voltage readings, could this be the problem? My small utility trailer with the flat-4 connector has no issue. Any thoughts/help would be appreciated, thanks.
Old Oct 26, 2024 | 07:26 AM
2015 F-350's Avatar
2015 F-350
Did you find your problem?
Old Oct 26, 2024 | 08:25 AM
Reverend Jim
Veteran: Navy
(Thanks for asking, I totally forgot to update this).
Yes, it was the aftermarket tail lights on my trailer with the reverse light built in. When in reverse, it would throw the "trailer disconnected" message because the light was faulty in the circuit board. Dealer couldn't find any issues on the truck side. Took a while to trace it down. I have since added 2 small cube lights for reverse, and now all is well.
Jhunter134
2009 - 2014 F150
May 8, 2022 09:00 PM
ORCM
Oct 26, 2021 12:29 PM
twesslen
Mar 30, 2017 08:43 AM
170Workhorse
Feb 16, 2017 09:26 PM
timmyboy76
46
Jan 9, 2017 07:37 PM
