Charging trailer batteries
My phone doesn't "yahoo" to well, but did find this exert..(pic coming). I had "thought" I taped into the correct write at the time to feed my auxiliary reverse lights, however when trailer is plugged in, they light up, lol. They also light up when NOT in tow, and in reverse. Anyway, looking for any insight on how/what can I use, to make my trailer batts charge while towing...
.......QUOTE......
.......QUOTE......
Found a few diagrams.... What would the AUX be coupled to? If my extra reverse lights are Chevy, then my aux spade IS the reverse light spade which is mentioned in the "quote" section Think, the 12v spade would be the charging circuit.
Say something about this photo
Received 3,692 Likes
on
Just use a test light and check the pins on the seven pin and you should be able to tell what is what pretty easily. Better still, for just a very few bucks you can pick up a tester that plugs right into your seven pin at any Advance, etc. and it lights up to show you what is activated when.
If you did any wiring yourself, the most common mistake I have seen folks make is confuse the wiring diagram as to whether the diagram they are using is facing the front or back of the seven pin wiring diagram.
Steve
Steve
on
Steve
Steve
i also see problems with wire colors where someone wired the plug with the color code on the plug and not what the wire does and where it should go.
All super duties have a removable harness by the spare tire that connects to the 7-way directly. Some trucks have been modified. If you find your truck wiring is messed up, unplug that short harness and inspect for incorrect modifications at the back of the truck. You an buy a new 7 way complete with harness at many auto stores or on the internet.
Larry
Larry
on
Will do... What still chaps my a$$, is plugging in trailer plug and the LED's light up, but not the reverse lights on truck, in which the led lights are what they're tapped into.
. Got my cig lighter wired up which is mounted into the rear bumper. For air compressor purposes😉
does both the LED and factory backup lights work when the trailer is not connected?
. As for the loom being messed with, nope..only when I decided to get in there....
Steve
