Issues With Sync 4
Old Jul 21, 2024 | 10:33 AM
2020KR350's Avatar
2020KR350
Issues With Sync 4
I have a 2024 F450 Platinum and yesterday we went to go out to eat and the screen came up to the splash screen with the Ford Blue oval and would not go any further. I did the reboot by holding the power and skip forward button several times with no success. This morning still doing the same thing. Anyone have any ideas on how to fix this. We are in Waco Tx and will be driving home to South Ms late this afternoon, it will be a long drive without radio.
Old Jul 21, 2024 | 10:52 AM
srkr's Avatar
srkr
Might be OTA updating.
Old Jul 21, 2024 | 11:19 AM
2020KR350's Avatar
2020KR350
Auto updates are turned off and it has been this way for 16 hours now.
Old Jul 21, 2024 | 11:24 AM
srkr's Avatar
srkr
Might be time to update then.,no way for anyone to know. A guy I know is having same issue with his 2024 Platnium Tremor, power and >> are not doing anything either.
Old Jul 21, 2024 | 11:29 AM
bpounds's Avatar
bpounds
After 16 hours locked up, I would probably try a battery disconnect.
Old Jul 21, 2024 | 11:32 AM
2020KR350's Avatar
2020KR350
Ford’s site says software updates “All Set” “No action required at this time”
Old Jul 22, 2024 | 12:36 AM
andrew8406's Avatar
andrew8406
There was an update the other day, but like you, I had mine set to not auto update. I had to press the continue button to allow it.
I say this only because it’s possible that the update failed, if it somehow started. If this is the case, it’s likely going to need to go to the dealer to have it reflashed. Maybe someone here will have another solution, or maybe it’s something else… but the timing is suspicious with the update within the last week or two.
Old Jul 22, 2024 | 07:59 AM
2020KR350's Avatar
2020KR350
I pulled the fuse that is labeled Sync and it killed the power to the screen, not sure what else. After about 15 minutes I put the fuse back in and it was still hung up. I then disconnected the negative on both batteries for about 10 minutes and that fixed the issue for now.
Old Jul 22, 2024 | 09:57 AM
bpounds's Avatar
bpounds
I think that tells you it wasn't the screen that was locked up, it was another network module that was locked up and the sync screen was waiting for it.
Old Jul 25, 2024 | 01:14 PM
CBRshamu's Avatar
CBRshamu
4wd Low
sub'ed for further developments...
I have a '24 Platinum Tremor and I've had some goofy issues with my phone connection and self disconnecting from Sync. Self changing audio source as well. I started using Spotify instead of Pandora yesterday and the issues haven't reoccurred..
tomfordgt
Apr 27, 2024 04:11 PM
Beast2.0
Oct 23, 2020 06:32 AM
slowmans
6.4L Power Stroke Diesel
Oct 27, 2011 07:27 PM
7.3 Rocket
Connecticut Chapter
50
Dec 16, 2010 07:16 PM
Rollinon40's
1997 - 2003 F150
Nov 16, 2006 06:22 PM
