Factory Ford bedliner plug kit.
Old Jul 24, 2024 | 11:34 AM
Boss598's Avatar
Boss598
Trailering
I purchased a bedliner and light plug kit for a 2023 F350 short box. The oval plugs that are supposed to cover the bed lighting and don't even come close to fitting and snapping into the bedliner cutout. Is this a common issue with the Ford plug kit. Why do people sell products that don't work.
Old Jul 24, 2024 | 11:46 AM
4wd6.7L's Avatar
4wd6.7L
Shows how little I know, I would have assumed those plugs are only for use without the box lighting.
Old Jul 24, 2024 | 11:51 AM
Boss598's Avatar
Boss598
Trailering
If that's the case it would have been nice for the Ford parts counter person to tell me that when I asked them if they would work with the box lighting.
Old Jul 24, 2024 | 11:52 AM
seventyseven250's Avatar
seventyseven250
What are you hoping for that plug to do? I'm confused.
Old Jul 24, 2024 | 12:59 PM
Boss598's Avatar
Boss598
Trailering
Just looking to cover the lights and openings when I get a load of stone or dirt dumped in the box. I'll machine up some covers out of Delrin and make a secondary bezel mounting perimeter ring that will stayed attached to the bed liner.
Old Jul 24, 2024 | 01:50 PM
acdii's Avatar
acdii
What they sold you are replacement covers for truck beds WITHOUT lighting installed. A truck bed will have the lighting holes punched out on all bed, if it comes without lights, those covers are installed instead. This is the parts guy not knowing what the part is for.
What this and it should start where the bed is pictured, but look for the cover.
Old Jul 24, 2024 | 02:00 PM
4wd6.7L's Avatar
4wd6.7L
https://youtu.be/Dx6LXWEwxek?t=157
I believe this is what the OP purchased, or intended to purchase https://accessories.ford.com/drop-in...9&gad_source=1
It includes plugs/blanks very similar to those that come in the bed of trucks without lighting, but in this case they are used for cutouts in the drop in bed liner. They sell a lower hole kit too.
Old Jul 24, 2024 | 03:13 PM
acdii's Avatar
acdii
Read the fine print though
Simply remove any equipment attached to the standard interface plates and then fill the access holes with these plugs; when done, remove the plugs and reattach equipment.
IE lights etc. What the OP pictured looks no different from the non lighted bed plug. So the bed lights come out in order to use the liner plug.
Old Jul 24, 2024 | 08:56 PM
Boss598's Avatar
Boss598
Trailering
You are correct. That is what I purchased. "2 lighting plugs included". They just forgot to say not for use with lights.
Old Jul 25, 2024 | 06:35 AM
99powerstrokedF250's Avatar
99powerstrokedF250
Yeah my wife's '19 F150 had the drop-in liner, and it didn't come with those plugs because it had the bed lighting. If we'd wanted to haul gravel or dirt up that high, we'd have had to cover the lights or remove them and use these plugs. Probably faster and easier to just cover them up with something instead.
Old Jul 25, 2024 | 09:23 AM
acdii's Avatar
acdii
Duct tape, reuseable too, well, off the roll that is. Looks like the kit includes the plugs for the lights and for the tie down fixtures which the name totally escapes me, which has to also be removed to plug the liner.
Old Jul 25, 2024 | 06:52 PM
Squanto's Avatar
Squanto
Yeah, my thoughts. Duct tape or flex seal.
Homeby5
Dec 21, 2021 02:31 PM
reconstyle
Dec 27, 2020 06:42 PM
mikekerr
Modular V10 (6.8l)
Dec 10, 2020 12:32 PM
jesterdog
Aug 11, 2010 02:55 PM
BADAS03SVT
Sep 1, 2008 03:30 PM
