ok im not sure if the new ford flash did this or me reflashing my truck, but I believe my navigation map used to be my home screen? its now the radio split with the ford symbol....how do you set the map to be your home screen when you start the truck?
I think pressing that house icon button gets to the home screen options. But I don't think I've ever played with it.
Mine defaults to the split screen with the map on the left and the graphic equalizer thing on the right regardless of what I had there earlier..
Same thing with display brightness. It's on maximum brightness at dawn or at night regardless of previous setting if I leave the auto-dim disabled. Auto-dim enabled is still too bright at night. I have a wear spot on my screen that's right on top of the brightness decrease button from all the times I turned it down. Annoying!
