E4OD wont shift into 3rd under load
Old Jul 7, 2024 | 04:58 PM
SoaDMTGguy's Avatar
SoaDMTGguy
Problem: Transmission will not shift into third under load. If I take my foot off the gas, wait a couple seconds, then get back on gently, it will shift. However, it then cannot make up its mind if it wants 3rd or OD.
Background: Original problem was no OD/intermittent OD, but everything else worked fine. Replaced torque converter and front pump. "Final drive" ratio seemed improved, but still no OD. Took apart transmission valve body/accumulator/etc, cleaned gunk out of channels, replaced.
After putting valve bodies back together, the shifting into third problem started. I redid my work, this time replacing the gaskets on the big steel plate, and also replacing the solenoid pack. Still no change.
Most recently I fixed slop in my shift lever and adjusted the shift cable. That improved 1st/2nd selection a bit, but still no 3rd unless I back off the gas.
I'm assuming it has to be related to the valve body stuff I did. Is it possible I put one of the ***** back in the wrong spot, causing this problem?
Old Jul 7, 2024 | 05:41 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Are there any codes stored in the PCM?
My Nightmare
Apr 6, 2024 06:55 PM
kingary49
Nov 25, 2023 02:49 PM
DeathRangerofDeath
Dec 21, 2016 01:43 PM
almo192000
1997 - 2003 F150
Jan 22, 2008 06:48 PM
theman79
Feb 18, 2007 09:12 AM
