Sponsored by: Auxito
trany shift problem
Old Jan 22, 2008 | 08:44 AM
almo192000's Avatar
almo192000
Question trany shift problem
i have a 1999 ford f150 4wd , i just had the transmisson replaced with one from a salvage yard. i am still having the same shift problems as i did when i had the original tranny in the truck. will not shift from 2nd to 3rd . we think it might be electrical , and am considering taking it to a garage. is there a need to reset the computer? any help would be most welcome.
Old Jan 22, 2008 | 12:09 PM
projectSHO89's Avatar
projectSHO89
Take it to a garage. You're in over your head.
Old Jan 22, 2008 | 03:42 PM
LastSplash's Avatar
LastSplash
Are you sure the 2-3 shift is bad and not the 3-4 (OD)? I think the 1-2 & 2-3 shifts are controlled hydraulically by the valve body. The 3-4 shift is controlled by the PCM via the solenoid pack in the transmission.
Old Jan 22, 2008 | 06:38 PM
almo192000's Avatar
almo192000
i believe you are correct, because when i have the od on it will not shift into od
Old Jan 22, 2008 | 06:48 PM
projectSHO89
Except for manual 2nd or for reverse, ALL shifts are electronically controlled by the PCM using the shift solenoids.
