'91 E4OD Issues
I've checked my FIPL/TPS voltages (sensor side only- I'll try to measure them on the computer side). It was out of spec at 1.2v no throttle. I've adjusted it to 1.1v with no perceiveable impact on the shift timing. I also tried 1.0v without any improvement. The max voltage at full throttle remained around 3.5-3.8v for each.
Are there any other obvious things I should check? I don't have an OBD1 scanner or adapter to check for codes- Is there a way to jumper the diagnostic port to flash the codes on the dash?
I have a few updates. First, the tps/fipl adjustments seemed to have fixed the shift timing issue. Not sure why the new calibration didn't fix it immediately, but the shift timing was fine after it sat overnight. However, it still has an issue in 3rd, and the OD light has started flashing. Went to pull the codes and realized that the self-test connector is mangled and the wires were pulled out.
Thankfully, I was able to find the appropriate wiring diagram with the color codes for the wires:
However, I wasn't able to get the self-test to work. I connected the self test input to the signal return, turned the key to on and pressed down the accelerator (as described in this write up: https://www.fordtruckzone.com/thread...canner.659319/) but the check engine light didn't flash. I'll try it again with a test light just in case the bulb is burnt out. Is there anything else that would prevent the self test from initiating?
EDIT: Yep, the bulb was burnt out. I was able to record the test light with my phone while I pressed the accelerator from the cab. Now to parse through the video and get the codes.
Hard Fault Codes:
- 93: Converter clutch circuit failure
- 99: Electronic pressure circuit failure
- 29: Insufficient input from vehicle speed sensor
- 67: MLPS out of range (/ AC on?)
Clutch Switch Circuit Failure - 99
29 could also be a wiring problem to the vehicle speed sensor (VSS) located on the rear axle. My first step would be to clear the code and see if it returns.
If the AC wasn't turned off when you ran the codes you'll get this code. You'll also get it if the trans wasn't in park when the test ran.
As for checking the Converter Control Circuit and the Electronic Pressure Circuit leads, are these the right wires to check?
Last week, the truck has been blowing fuses 1 (Hazard lamps, Speed Control) and 5 (turn signals, backup lights, and the overdrive circuit). It seems to blow them at random. Sometimes they last for 10-15 minutes, sometimes they blow almost immediately. There isn't any clear correlation that I have found between the fuses blowing and any observable phenomenon. The main issue (aside from no turn signals) is that the transmission will not stay in third gear. It will briefly shift into third before shifting into OD (regardless of the state of the OD switch, or vehicle speed), so I effectively have no third gear.
There may be a short in the MLPS, as fuse 5 is in circuit with it- I'll be checking that shortly. In any case, I really need third gear. Barring a clearly faulty MLPS, Is there any way I can hack into the E4OD wiring harness to forcibly disable overdrive or lock the transmission into third gear while in drive? I only need the transmission to get me there and back, so as long as it is drivable, I don't care how much of a hack job it is.
Are you sure it's shifting 3-4? Usually the torque converter locks immediately after the 2-3 shift. With the OD off the PCM prevents shifts to fourth gear.
