No FICM sync
Old Jun 19, 2024 | 12:20 PM
MotoStu's Avatar
MotoStu
No FICM sync
I'm making a new thread since my previous was more related to concerns over the high pressure oil system.
I had another crank/no start today. In looking at FORScan, all is good except there is no FICM sync. Working to troubleshoot now based on what I can find searching, but have a question:
I see RPMs in FORScan while cranking, though they are inconsistent (jumping around from the 60's to high 100's even though it is a steady crank). I do NOT see the tach needle move at all. Does that maybe indicate I should focus on the CKP and associated wiring?
Old Jun 19, 2024 | 02:02 PM
bismic's Avatar
bismic
I would .
Old Jun 19, 2024 | 04:40 PM
Excurvelle's Avatar
Excurvelle
A little tip on the Crankshaft Position Sensor without reading the .pdf. Disconnect the batteries, remove the nut holding the negative cables. Remove the starter cables from starter and pull through the front of the frame. out of the way. For me this was the hard part, disconnecting the wiring front the sensor, IDK why it kicked my tail. 8mm bolt holds the sensor in, remove and reinstall in reverse order.
1st time I did it was in an Autozone parking lot in Southern AZ, my stomach got sunburned
Old Jun 19, 2024 | 07:02 PM
MotoStu's Avatar
MotoStu
Thanks guys. I wiggled the connections on the sensors to make sure they were secure and also disconnected/reconnected the associated connector on the PCM, and it started. Problem is, I didn't try starting after each thing I did, so don't know what fixed it . My bad on that.
So, looks like the sensors are fine, and either I just had a bad connection or have a chafed wire and will be doing this again
I appreciate the tips, too, for getting easier access to the crankshaft sensor if I ever do need to replace it.
Old Jun 19, 2024 | 07:06 PM
bismic's Avatar
bismic
The sensor itself is more reliable than the connector. They used to sell the connector o-ring by itself, oil leakage damages the connector.
3C3Z-9C064-DA (for the o-ring IIRC)
https://www.tascaparts.com/oem-parts...ng-3c3z9c064da
Pigtail part #: WPT-359, or 3U2Z-14S411-CGC
https://prosourcediesel.com/shop/bra...ail-4ft-leads/
Just in case the need arises.
Old Jun 20, 2024 | 08:35 AM
Excurvelle's Avatar
Excurvelle
How in the heck do you access the connector to replace it? There is no room down there.
Old Jun 20, 2024 | 08:47 AM
bismic's Avatar
bismic
Two helpful videos:
Old Jun 20, 2024 | 01:38 PM
MotoStu's Avatar
MotoStu
Good videos. Hopefully I can pinpoint the issue if/when it happens again so I can fix it for good.
Stranded 6.0
Jun 23, 2023 08:16 AM
waumpuscat
Jun 28, 2012 12:07 PM
Javo
May 28, 2012 08:17 PM
FSeybert
Nov 17, 2011 07:55 PM
nesloe1
19
Feb 28, 2007 05:08 PM
