Starter issues
Old May 22, 2024 | 08:53 PM
TristanTyler454's Avatar
TristanTyler454
4wd Low
Starter issues
I have a 96 F150 5.0 that I manual swapped off a 95 donor truck. I got a new brute force manual 164 tooth flywheel, and a new manual duralast starter. I got everything put together and went to start it up. The starter made a grinding sound and wouldn’t start the truck. Anyone have any advice on this? I was told on another group that I needed to buy the transmission, flywheel, and starter as a set, and that since I didn’t buy them as a set they won’t work together? I attached a video of what the truck sounded like when I tried to start it
Old May 23, 2024 | 08:28 AM
1Butcher's Avatar
1Butcher
You lost me with Duralast starter. Start with good parts and projects usually cost more with less problems.
Old May 23, 2024 | 08:31 PM
TristanTyler454
4wd Low
Update, I took a file to the separator plate and filed it down enough to get the starter to engage. It starts up fine now. I’m gonna borrow a dremel and grind it out some more to clean it up
Old May 23, 2024 | 11:55 PM
wwhite's Avatar
wwhite
Did you swap the separator plate?
Or do you still have the auto one with the inspection cover?
1984F-150
Sep 13, 2023 03:18 PM
jamesh23
26
Jul 19, 2016 10:47 AM
DrZoom
16
Apr 6, 2016 11:42 AM
fish-albuq
Dec 30, 2009 04:23 PM
Corbin18
1978 - 1996 Big Bronco
Aug 27, 2004 08:55 PM
