Oil dipstick - trivia question.
I'm trying to determine how much oil my '01 E250 is using. But the dipstick has 2 different sets of marks. One is a crosshatch section, the other two holes spaced apart about an inch.
Why are there 2 sets of marks?
Does one set indicate 1 quart? Which one?
- Thanks
- Thanks
It's the 5.4L. I don't know.. I'm assuming one of the sets of marks denotes 1 quart, but maybe neither one does. I checked the owners manual and it doesn't provide that kind of detail. I guess next oil change I'll bring it up to the bottom mark, add 1 quart, and see where it ends up.
Do you compare how much you drain vs how much you fill? Don’t forget what’s in the filter.
Does it drop evenly between oil changes or is it stable then drops quickly? Dropping quickly later could be oil degradation.
We change Mobil1 5W-20 at 5000 miles. It drops some particularly with heavy freeway runs but not a quart and I don’t add oil between changes.
Sixto
07 E350 5.4 198K miles
Sixto
Sixto
Sixto
I'm curious if 6000 miles per quart is low, typical, or high for this engine (5.4L 2-valve) and its age (130,000 miles).
Try a poll in the modular V8 forum:
https://www.ford-trucks.com/forums/forum48/
Dealers/manufacturers typically don’t take warranty action until consumption is a quart in a thousand miles.
I think it’s higher than our 5.4 but it’s not apples-to-apples since we change sooner than you.
Sixto
Sixto
No, not excessive. Even double that is not excessive. One quart in a thousand miles is excessive oil consumption
I'm running a '05 5.4 w/311K and according to the FSM it takes 7 quarts with filter.
The oil should be in the hash marks, not below, that means you a quart low. I'm running Mobil1 5w-20 and burn 1 quart every 2K mostly highway driving.
Hmm… we must have the extended ground clearance shallow sump option. Owner manual says 6qts for our ‘07 5.4 (all gasoline engines). No mention of filter. I don’t have a ‘07 FSM to compare.
To the original question, manual says oil level should be between the dots. Nothing about hash marks. Also says don’t add oil when level is between the dots.
Sixto
Sixto
I missed that rule of thumb. Other manuals have oil capacity specs with and without filter. This one has one number for gasoline engines (4.2, 5.4, 6.8?). I’m inclined to believe Ford was under pressure to reduce the environmental footprint and revised the printed spec to 6qts without changing dipstick.
That said, I’m curious what the ‘07 FSM says about oil capacity.
Sixto
Sixto
68FordTruck
11-06-2021 03:21 PM
fred-texas
07-01-2018 10:10 AM
