Crank no start
Old May 13, 2024 | 01:15 PM
Superdutybeginner's Avatar
Superdutybeginner
Trailering
Crank no start
Hi there!!!My vehicle: 2005 F250 6.0 Powerstroke Superduty Lariat Im new to diesel engines but have a little understand' anyhow heres my problem. i recently changed all injectors. prior to change truck ran fine all except for a hiccup due to cylinder #3 contribution/balance dtc. After replacing injectors truck will not start. Batt: 12.5v KOEO.. 10.5 crankFICM 48.00 KOEO.. 48-48.548-48.50 crankICP 0psi KOEO.. 1400-1600psi crankPulse Width is jumpy between 1.8 and 6.3 during duringIPR 14% KOEO.. 84% crank
Additionally when cranking it acts like it wants to start but won't turn over. Oil pressure is good fuel pump is good.
I'm at a loss I've checked multiple forums and have tried what was suggested in them to no avail any and all help is appreciated. Thank you
Old May 13, 2024 | 01:44 PM
bismic's Avatar
bismic
You have insufficient ICP pressure. The pressure values you are reporting are likely to be assumed numbers (ie not real). To know the real numbers, you need to monitor the ICP sensor voltage output.
Old May 13, 2024 | 04:53 PM
Superdutybeginner
Trailering
Originally Posted by bismic
You have insufficient ICP pressure. The pressure values you are reporting are assumed numbers (ie not real). To know the real numbers, you need to monitor the ICP sensor voltage output.
What voltage should I look for and also how would I check that voltage?
The tool I have only allows me to monitor pulse width and the icp (false readings)
Old May 13, 2024 | 04:59 PM
bismic's Avatar
bismic
What are you using?
Old May 13, 2024 | 05:05 PM
Superdutybeginner
Trailering
I am using the Guage monitoring system on my sct livewire ts+ tuner. (I did take off the tune that was on it as well)
Old May 13, 2024 | 05:18 PM
bismic's Avatar
bismic
You really need to get a good scan tool - anyone who owns a 6.0L needs one.
.85 volts is going to be about the minimum sensor voltage output to start. Personally I wouldn't mess with trying to backprobe sensor contacts to see the sensor output - just get a good scan tool. FORScan Lite for a smartphone is very good and pretty cheap. Torque Pro is pretty cheap also. You want a scan tool that reads codes thoroughly - tuners can't do that.
That said, it seems that you are heading for an air test of the high pressure oil system.
Old May 13, 2024 | 06:39 PM
Superdutybeginner
Trailering
.85 volts is going to be about the minimum sensor voltage output to start. Personally I wouldn't mess with trying to backprobe sensor contacts to see the sensor output - just get a good scan tool. FORScan Lite for a smartphone is very good and pretty cheap. Torque Pro is pretty chap also. You want a scan tool that reads codes thoroughly - tuners can't do that.
For a scanner are think of something like this
Old May 13, 2024 | 07:33 PM
bismic's Avatar
bismic
Is that just the adapter, or does that include the FORScan software to download to your laptop?
Old May 13, 2024 | 07:42 PM
Superdutybeginner
Trailering
That's from forscans website where they have the software to download
Old May 28, 2024 | 09:57 PM
Superdutybeginner
Trailering
I fixed this problem it turns out one of my harness ends was unplugged on the FICM. So dumb 😤😤😤
Old May 28, 2024 | 11:32 PM
BLADE35's Avatar
BLADE35
hey you figured it out congrats
thanks for the update
Old May 29, 2024 | 04:16 AM
bismic's Avatar
bismic
I am not sure how a bad FICM connection can result in an 84% IPR command when cranking, but anyway - As Benny said, glad it is running again.
EDIT - I guess I spoke too soon ............
So from the last post above to your other thread in only a few minutes, or I guess I am misreading the post?? Maybe you only meant that you solved ONE of your (several) issues.
https://www.ford-trucks.com/forums/1...e-driving.html
Superdutybeginner
May 12, 2024 04:46 AM
Christian3144
1997 - 2003 F150
23
Jan 2, 2022 07:26 AM
Isaacm
May 27, 2021 09:34 AM
fordummy
Aug 9, 2019 03:10 PM
kx450f
Nov 16, 2012 09:32 PM
