Crank but no start
Old May 24, 2021 | 10:14 PM
Isaacm's Avatar
Isaacm
Crank but no start
We recently bought a 2005 ford f250 with the 6.0L diesel and we bought it knowing it has engine issues so we replaced the ficm we checked that it was getting fuel and that it was getting oil up to the oil filter we have good batteries when the engine cranks it sounds like the injectors aren't firing my thought would be something with the hpop but am not sure about it the guy we bought it from said he was driving down the road and it was like someone turned the key off and he tried starting it but wasn't able to get it started at all and had let the truck sit since 2019 any help would be appreciated!
Old May 25, 2021 | 12:11 AM
xcrsp440's Avatar
xcrsp440
Watch this. You need to get a tool to read sensors. There is a cheap smart phone app called Forscan for $5 and you will need a wireless adapter to plug into your OBD port $35 from Amazon.
Old May 25, 2021 | 12:32 AM
Isaacm's Avatar
Isaacm
Will test the obd scanner and see if it works thank you for the advice!
Old May 25, 2021 | 09:37 PM
IHateCommieCars's Avatar
IHateCommieCars
Woohoo! Let's all just throw some idea out, whatever we think it might be. Prolly only 20 or so really possible things it could be. Maybe a Closest to the Pin contest where we all ante up $20, winner take all. I'll go first and say the IPR valve is stuck open. Something blew through the screen and is wedged in the valve. 30 mins and some carb cleaner; it runs good as new.
Next?
Old May 26, 2021 | 07:22 AM
Brotherbillstruck's Avatar
Brotherbillstruck
Next?
Wild tee shot-Fuse 22! Where do I send my $20?
Old May 26, 2021 | 08:20 AM
Visurveyor's Avatar
Visurveyor
Yank the valve covers off and replace Dummyplugs, standpipes they COULD be leaking. I'm in for $20
Old May 26, 2021 | 09:57 AM
xcrsp440's Avatar
xcrsp440
STC fitting let loose is my guess.
Old May 26, 2021 | 08:58 PM
IHateCommieCars
OK, the pot is at $80! I guess it's OK for more than one person to guess the same thing? They'd just split it up like lottery winners, lol.
For the record though, in case it wasn't obvious, I was actually just yanking Isaac's chain.
Old May 27, 2021 | 06:32 AM
Visurveyor's Avatar
Visurveyor
We all were Commie.
But until he gets a monitoring system set up and scans for codes and post some up readings there's not a whole lot we can do but guess. Hell, the price tag on our guesses is up there in parts and labor already.
Old May 27, 2021 | 06:48 AM
IHateCommieCars
Yep, the guys here are good, but not that good, lol.
Old May 27, 2021 | 06:53 AM
bismic's Avatar
bismic
An all-around favorite tool:
https://www.forddoctorsdts.com/psd8ball/
Old May 27, 2021 | 09:22 AM
Visurveyor's Avatar
Visurveyor
Damn Mark might have to go to voodoo next time mine -hits the wad.
That's a good one. Put a smile on my face.
Old May 27, 2021 | 09:34 AM
bismic's Avatar
bismic
ford_doctor was kind enough to re-post the link to that, it is an "oldie".
Cms300
Jun 7, 2016 01:12 PM
KevinPC13
May 25, 2013 05:54 PM
mudslinger83
Apr 25, 2012 09:28 PM
SAT-LLC
Oct 3, 2010 09:12 PM
lhuninghake
Sep 3, 2008 12:40 PM
