Flex plate to torque converter
Old May 6, 2024 | 08:13 AM
jack6109518's Avatar
jack6109518
Morning, fellas.
When I bolted up my trans to the engine (C6 - 351W) last night I first rotated the converter so that one of the studs was at 6 o'clock with the drain plug right next to it.
Then I rotated the engine clockwise until one of the four holes for the converter connection in the flex plate was also at 6 o'clock.
Everything went together relatively easily. I torqued the bellhousing bolts and the converter/flexplate bolts to spec.
My question is this - Is there a certain way that converter should connect up to the flexplate regarding balance?
Thank you - Thomas
Old May 6, 2024 | 09:21 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
No, there is not.
Old May 6, 2024 | 09:27 AM
jack6109518
Originally Posted by Mark Kovalsky
No, there is not.
Got it. Thanks, Mark.
- Thomas
Crafty969
Dec 31, 2023 02:50 PM
thedieselkid
May 15, 2013 05:09 AM
Tomget
Jul 27, 2012 11:54 AM
supercab78
Mar 19, 2006 02:30 PM
karljay
Oct 24, 2002 06:28 PM
