HPOP - T500 vs Adrenaline
Old May 8, 2024 | 11:21 AM
PriusLover's Avatar
PriusLover
Originally Posted by Alexis Garcia
My stock pump is becoming very leaky and hasn’t been replaced (400k miles). Was think a new stock pump or upgraded pump
By leaky do do you mean the end cover is leaking? If not, where is it leaking from?
If your pump, regardless of miles, holds ICP fine in your use case you'd probably be fine just re-sealing your current pump.
Old May 8, 2024 | 11:46 AM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
IPR duty cycle kept climbing while ICP kept falling. The progression from start of failure to total failure was quite rapid unfortunately. About all I was able to do each time I noticed imminent failure was to pull over to the side of the highway safely before the engine stopped running.
In the case of the Adrenalines, the cylinder barrel had spun on the input shaft. I found that odd since DieselSite claims to pin those parts together on their Adrenalines. I forget what happened to the T500.
Keep an eagle eye on your IPR duty cycle vs ICP. These two parameters are permanently displayed on my Scangauge II which is placed smack in my line of sight as I drive.
Thank you for your detailed response.
One of these days I might actually try that.
In the meantime, my modus operandi has been "ignorance is bliss."
In the near quarter of a century that I've had my truck, I've not even once ever looked at my IPR duty cycle, nor have I ever looked at my ICP.
Still on original stock HPOP, and as yet I just haven't encountered any need to check those parameters.
And it isn't as if I don't have the means to check...
Of course if I start looking, I might end up swapping HPOPs, adding reservoir volume risers, breaking corner castings, trying dual HPOPs...
I think I better not look. Ignorance is bliss.
Old May 8, 2024 | 01:25 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
What is that?
Old May 8, 2024 | 01:56 PM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
That's yours.
Old May 8, 2024 | 05:58 PM
FordTruckNoob's Avatar
FordTruckNoob
Oh c’mon. YOLO!!!
Old May 8, 2024 | 06:06 PM
97-psd's Avatar
97-psd
As curious as you are, I am surprised you have not at least looked at it to verify system health.
Old May 9, 2024 | 10:27 AM
derek0525's Avatar
derek0525
I would personally stay away from anything Dieselsite makes. With the headaches I have gone through with 2 of their products this week. And in the past lessons learned. I have not heard of a lot of issues with the adrenaline pump but for the price I would look elsewhere CNC fab is most likely where I would go for a pump.
Old May 9, 2024 | 11:58 AM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
I think my system health verification metric has thus far been
"Did I get there?"
(Yes)
"Must be OK."
Old May 9, 2024 | 05:23 PM
Dan V's Avatar
Dan V
"Did I get there?"
(Yes)
"Must be OK."
"Did I awaken today?"
(Yes)
"I guess God isn't done with me yet."
94iditpuller
Jan 27, 2016 11:42 AM
xjpilot
18
Feb 21, 2012 01:32 AM
97-psd
Nov 27, 2009 09:47 AM
KevinC.
23
Apr 4, 2009 05:29 PM
mueckster
29
Jun 20, 2006 09:29 PM
