I should probably upgrade the mechanical fuel pump for a 347 huh?
If you have to buy a new pump, why don't you opt for a mechanical Edelbrock pump ?? That's all my 460 has, as approved by my machinist. Eddy too lists the same part number for 302 and the 351W. The price difference between a stock one and the Edelbrock pump is pretty much negligible considering the money and time you have into a 347 build.
Designed for use with all Edelbrock carburetors used in Performer or Performer RPM applications. These high performance Street Fuel Pumps feature a high quality three stage polished finish. The unique valve design improves flow quantity and quality, and will support engines up to 600 hp. High-volume, 3/8" NPT inlet and outlet surpasses the capacity of conventional models. Produces 6 psi and does not require a regulator. For gasoline only. Clockable lower housing can be rotated for best inlet/outlet alignment.
Seems pretty straightforward to me - does not require a regulator. Therefore less plumbing, less chance for the gas to get hot, less chance for leaks, etc. I'm sold.
Appreciate it Gary.
The cherry on the cake for the Eddy combo can be using their braided hose pump to carb kit connected to their rebuildable high flow fuel filter and inlet kit.
Edelbrock Filters and Accessories
Appreciate it Gary.
Having said that, the filter element doesn't thrill me. Don't know what filtration capability the pleated paper ones I'm using have, but I'd bet it is more than the 40 micron that the E'brock has - especially given that it is a screen. Since our tanks are getting rather old and spitting rust, I like to run the see-thru pleated paper filters as I know they take out a lot of the gunk because I can see it. I've had the accelerator pump discharge passages clog up due to that silt when running screen filters, but not since I went to paper.
