pusher pump
Old Jun 1, 2006 | 09:21 PM
mueckster's Avatar
mueckster
pusher pump
To those who have added a pusher pump,
What pump are you using and what are the pressure and gallons per hour specs?
Thanks in advance for your replies,
mueckster
Old Jun 1, 2006 | 09:24 PM
jtharvey's Avatar
jtharvey
I don't have one yet, but several of the guys here have used a Carter pump, like the Street/Strip pump or the Silver pump seen here: http://www.jegs.com/webapp/wcs/store...tegoryId=10307
A few have used the Holley Red and Holley Blue pumps as well. Any of them will work. Just use what you prefer, or can find the cheapest at any given time. Typically want to use 5-9 psi and 70+ GPH flow.
Old Jun 1, 2006 | 10:02 PM
guzzle92's Avatar
guzzle92
Yep, that's the one I'm using and it definitely makes a difference. It makes a little more noise when you turn the key on, but can't hear it once the engine starts.
Old Jun 1, 2006 | 10:13 PM
mueckster's Avatar
mueckster
guzzle92,
Did you wire into the stock pump wiring? What is the amperage draw for this pump?
Old Jun 1, 2006 | 10:40 PM
guzzle92's Avatar
guzzle92
Yes, I wired it in parrallel with the factory pump and can't tell you what the exact amp draw is, but the original fuse has been able to handle both of them. This is the way that cookie wired his and works fine since it only runs when the factory pump is running.
Old Jun 1, 2006 | 11:42 PM
WA.Ranger's Avatar
WA.Ranger
I' m with Guzzle. I've got the same thing, and the fuse has been holding fine. My rig is my daily driver also.
Old Jun 2, 2006 | 12:53 AM
Kwikkordead's Avatar
Kwikkordead
I put my fuel pump inside my tank.
Old Jun 2, 2006 | 05:41 AM
PSNut's Avatar
PSNut
I also have the Carter pump in parallel...no problems. Keep a spare fuse kit handy.
Nut
Old Jun 2, 2006 | 06:05 AM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
i want to take this idea and kind of transform it into another common modificaiton like Kwik. put a pusher pump (lift pump) in the tank, and then have the stock one on the framerail. can this be done, and if so, with what?
Old Jun 2, 2006 | 07:37 AM
mueckster's Avatar
mueckster
Many of the earlier Ford MPFI gas engines used a lift pump in the tank and a hi press pump in the frame rail. You could easily adapt one of these to the fuel line in the tank. They attach with hose. I tried to find some specs on the pumps, but was unable to. But, these pumps were designed to do what you asking. I changed out the sending unit/ fuel pump assembly on a '87 Ford Ranger V6 with such a pump. You can buy the pump by itself. It seems like this pump and strainer would work. Or, you could adapt the factory strainer to the bottom of the pump.
Old Jun 2, 2006 | 11:28 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Nut
You've popped a fuse?
Old Jun 2, 2006 | 11:46 PM
monsterbaby's Avatar
monsterbaby
I am running a holley red pump (7psi, 97gph) wired it to the factory wiring, been what a month or so never popped a fuse yet, and still working great.
The intank pump Idea would work good too expecially since doing the intank mod you need to splice the line to the pickup anyway you could just shorten the whole thing and put the pump inline with hoses instead of a coupler for the steel hard lines. running the power to it would be the hardest part and I think that could be resolved easy enough with a through bulkead wiring connector of some type.
Old Jun 3, 2006 | 05:12 AM
PSNut's Avatar
PSNut
Nope....no fuse popped yet.
Old Jun 3, 2006 | 12:46 PM
cookie88's Avatar
cookie88
FTE Emeritus
Oh..ok. I haven't had a issue either. I thought since you posted that "carry a spare fuse" deal that you may have had a problem.
Old Jun 20, 2006 | 12:29 PM
TNT in Round Rock's Avatar
TNT in Round Rock
any of you guys running one in parallel have a photo of any of the modifications ?
