17* hpop
Old Apr 1, 2009 | 09:26 PM
KevinC.'s Avatar
KevinC.
17* hpop
My stock 15* HPOP is getting weak, I was wonderin if any of yall have a 17* pump you could part with. I'd rather pay a fellow FTE member than the stealership.
Thanks
Old Apr 2, 2009 | 09:51 AM
superduty4x4's Avatar
superduty4x4
Thanks
Send Joey (Terminator Engineering) a message on here... he'll sell you a modded 17* pump at a great price.
Old Apr 2, 2009 | 11:09 AM
KevinC.'s Avatar
KevinC.
I have heard very mixed opinions about that pump. And I know the one before it didnt work out. I'm leary on spending 470.00 on it. Have you heard any unbiased reports on that pump??
Old Apr 2, 2009 | 02:35 PM
superduty4x4
I have heard that Joey has changed some of what he does to the pump to decrease long crank times. So far people I've chatted with online seem happy. And $470? I don't think it's anywhere near that much. He quoted me much less to upgrade my stock 99 15* pump to a modded 17.
Old Apr 2, 2009 | 03:35 PM
triskit16's Avatar
triskit16
Might be thinking of the Adrenaline...
Old Apr 2, 2009 | 03:38 PM
superduty4x4
Duh... I bet you're right.
KevinC- Termy modded 17 is a whole different animal than the Dieselsite Adrenaline pump. The modded 17 is a stock HPOP with some work done to increase the flow.
Old Apr 2, 2009 | 03:47 PM
throwdown's Avatar
throwdown
Is longer crank time a sign of a weak pump? It has 262,000Kilo on the original pump.
Old Apr 2, 2009 | 03:49 PM
ron's power stroke's Avatar
ron's power stroke
i know i like mine so far..
Old Apr 2, 2009 | 04:14 PM
superduty4x4
It can be. At that mileage (or kilometerage... ) your pump could be getting weak. Could be weak batteries too.
Old Apr 2, 2009 | 04:22 PM
ron's power stroke
if you have long cranks all the time..check the reservoir before you start her up...if its low on oil.. then you may have a bad injector oring...
Old Apr 2, 2009 | 04:30 PM
throwdown's Avatar
throwdown
Batt's are original. This winter was the first time I have ever had a problem and the truck sat for three days at -25*C. When I went to start it there just wasn't enough juice. Put the charger on for a while and it worked out. No problems since and I have a habit of listening to the radio for hours if the truck is near where I'm working, ie doors open radio up, blah, blah, blah. I should check for specific voltage though I guess. They should be a bit tired.
Old Apr 2, 2009 | 04:33 PM
ron's power stroke
I should have waited for part 2 of your first post before i posted ..
Old Apr 2, 2009 | 06:02 PM
KevinC.'s Avatar
KevinC.
Ok youre right, I was thinkin of the adrenaline. Ok, so contact terminatoreng.? Thanks guys, I'll PM him. Now, everyday my truck fires almost instantly if it has been run that day, and on a cold start usually fires on the third turnover. I don't want a pump thats gonna take forever to start. I'm going to run AE as soon as I get ahold of my buddy with the software and see what my ICP pressures and IPR duty cycle is. But I thought I'd post over here since I'm gonna get an SD pump.
Old Apr 2, 2009 | 06:14 PM
KevinC.'s Avatar
KevinC.
His inbox is full, anyone know of any alternate contact??
Old Apr 2, 2009 | 06:16 PM
ron's power stroke
