ok, so I have been trying to decide which to chose, the adrenaline or the Terminator Engineering moded 17* pump. Both have their advantages, the TE pump is a NEW pump that is modified to flow more, and the Adrenaline is basicly a hopped up reman pump, but there are alot of happy Adren. followers out there. so what is your opinion?? I need something that will last for a long time without any worries so tell me what you think!!! help!!!
Bob has a good pump in the Adrenaline. Fills a niche. Joey's pumps are top notch also. As I really don't have any personal experience with either at this point this is just conjecture. Either will likely do you fine. But Terminator is the way I will go.
I don't plan on anything bigger then stage 1 injectors (at least for now) but I am still on stock injectors and programming. I installed the adrenaline a week or so ago.
which pump to use just depends really on which injectors you want to run. IMO both pumps cover the same range of injectors really. I love my TE modded 17*. no CELs with the stage 2's yet. haha
hey. i love my te modded pump. with my hybrids, i never get a cel and talk about top end power! granted, the ones i have use less oil than a stage 2. i wish i had a gauge so i can prove this pump rocks. what i also like about joey is the customer service. hes a great dude
97-psd I haven't really noticed anything. There may be a little bit but if someone had put it in one night and didn't tell me I wouldn't of noticed. My stock pump was still good because I was getting 2600 psi for a top pressure and maybe getting 2700 for this one, I have an external gauge hooked up to the head to read the pressures. I need programming to get any higher pressure, and injectors to make good use of it. I am checking my mileage also to see if there is any increase there.
