Hei distributor In 300 il6
Old May 4, 2024 | 05:07 AM
Lee'sFord's Avatar
Lee'sFord
My truck is almost finished after 17 months. I ran into a problem with my hei distributor. I have fire to the distributor, but no t to the spark plugs. I tested the coil and it's good. I replaced the module, but still no fire. This one has me stumped. Anyone else run into this?
Old May 4, 2024 | 05:36 AM
FuzzFace2's Avatar
FuzzFace2
A few things come to mind.
The HEI needs a full 12 volts. Do not use the resistance wire to power the HEI dist.
Are you sure you have power going to the right spade on the dist.?
I dont know how you are powering the HEI but some IGN switches may only power when in run and not start or the other way around.
You can check this with a test light on the HEI power wire in run and start modes, light should light in both.
If you hot wire, 12 volts from battery to HEI do you get spark and it runs?
If so then you get a issue with the IGN switch in my book.
If still no spark to the plugs check the cab and rotor for cracks or just replace both.
Note there should be a rubber washer in the cap under the coil.
Rotor button, rubber washer, coil and cover with screws.
IIRC there is a metal ground wire" from 1 for the coil corners to where the wires are in the cap.
I dont think I have ever seen anything connected but may want to try a ground wire to it.
Is the motor grounded to the battery and motor to frame and motor to firewall? Can never have too many grounds and the later trucks they were all grounded that way.
Cant think of anything else if it dont run hot wired then it is a bad HEI I guess?
Dave ----
Old May 4, 2024 | 08:30 AM
Crop Duster's Avatar
Crop Duster
Did you remove the pink resistor wire under the dash? It plugs into the ignition switch it has a green male connector on it. You have to cut it at the cowl connector and replace it with a solid wire.
Old May 4, 2024 | 11:40 AM
Lee'sFord's Avatar
Lee'sFord
Th we engine is on a 1962 Ford F100. I'll check these things and see of any correctvthe problem. 👍
Old May 5, 2024 | 05:27 PM
Lee'sFord's Avatar
Lee'sFord
Thanks for the insight guys. I have power to the distributor when I turn the key to on. When I turn to start, I lose power to the distributor. My truck has a wicked sense of humor 👍
Old May 6, 2024 | 04:15 AM
Crop Duster
I wouldn't blame the truck for that.
There should be a wire connected to the "I" terminal on the start relay. That wire was originally spliced into the wire going to the coil. It supplies 12V to the coil when the starter is engaged. It is in the wiring diagram.
Old May 6, 2024 | 10:37 AM
Lee'sFord's Avatar
Lee'sFord
Thanks CD, I'll try that. Yesterday's efforts were a bust. This is the worst part fir ne lol
Old May 10, 2024 | 10:38 AM
Lee'sFord's Avatar
Lee'sFord
IBecause of my inability to play nice with electrical and wiring, I solved the issue by a direct connect from the hei to the battery, with an on/off switch in line. Works, so I hope it holds 😆 ty CD, ty Fuzz 👍
Old May 10, 2024 | 11:40 AM
TA455HO's Avatar
TA455HO
Lead Gopher
That could double as a theft deterrent, too.
Old May 10, 2024 | 12:03 PM
Lee'sFord's Avatar
Lee'sFord
😆 yep, I got other tricks too
Tenderpaw
Jun 2, 2022 10:43 PM
JosePrado
Sep 7, 2017 11:56 AM
Ratt617
Nov 11, 2010 09:01 AM
sunnybottomboys.de
Nov 17, 2009 04:18 AM
OzarksFord
Oct 2, 2005 11:40 AM
