Distributor question 2
Old Sep 5, 2017 | 10:52 PM
JosePrado's Avatar
JosePrado
Hello again folks
No​​​​​​ spark in the distributor
I had my daughter hit the ignition
I saw the rotor spin but saw no spark
The points are set at .025 per chiltons shop manual
I checked TDC and positioned spark plug #1 and the distributor accordingly.
Its a 240 engine, 1969, f100
The previous distributor at least got the engine started
The distributor was incompatible w my carb
Now the carb and distributor are compatible
I must have done something wrong as I replaced the distributor
Old Sep 6, 2017 | 07:29 PM
JEFFFAFA's Avatar
JEFFFAFA
Originally Posted by JosePrado
Hello again folks
The wire coming out of the Dizzy (distributor), did you hook it up to the "-" negative side of the coil?
Old Sep 7, 2017 | 09:47 AM
JosePrado's Avatar
JosePrado
Yes, of course
Ill stsrt from scratch again and retrace my steps carefully
Ill share my results this weekend
Old Sep 7, 2017 | 10:10 AM
willowbilly3's Avatar
willowbilly3
Well, you obviously need to go purchase a 12 volt test light.
first check is if you are getting voltage to the coil +, and to the points (with them open)
Old Sep 7, 2017 | 10:59 AM
JEFFFAFA's Avatar
JEFFFAFA
Yes, of course
I did not mean to insult your intelligence. Anyone can forget a step. But you mentioned "no spark in the distributor". Which means there is no spark as the points open. The power leading to the points to create that spark comes from the coil. Via the wire I referred to. If you have no power at the points then you need to find where that power is stopped. As Willow posted.
Old Sep 7, 2017 | 11:44 AM
Tedster9's Avatar
Tedster9
Swap in the old condenser. The new manufacture condensers are all junk, for the most part. Very common problem anyway.
Old Sep 7, 2017 | 11:56 AM
JosePrado's Avatar
JosePrado
Yes, of course
jswisc
Jul 10, 2022 09:45 AM
PaxtonQ
Jul 7, 2017 09:28 PM
1950ford
Dec 16, 2007 10:15 AM
JRDOM
Electrical Systems/Wiring
Jan 30, 2004 08:33 PM
ScottDora
Feb 28, 2000 05:13 AM
