Hei Distributor connected to Duraspark Module?
Old May 30, 2022 | 09:50 PM
Tenderpaw's Avatar
Tenderpaw
I purchased a truck with a 429 engine swapped in and the engine has a HEI distributor (coil in distributor) but it has wires that go from the back of the distributor to the duraspark module. I have never seen this before. Can anyone tell me what kind of setup i have?
Thanks.
Dave
Old May 31, 2022 | 06:48 AM
DaveMcLain's Avatar
DaveMcLain
I'd pull the cap and check out the wiring. It is possible that it has been connected so that it uses the Duraspark box instead of the HEI module. Why that would be done? I don't know.
Old May 31, 2022 | 11:01 AM
manicmechanic007's Avatar
manicmechanic007
Might just be using the two power and ground wires from the small Duraspark module connector? And the others go nowhere?
I agree look to see if there is a GM module in the HEI
Maybe he was burning gm modules and just decided to mind meld it together
How many wires coming from the HEI? Maybe it's a computer command control C3 distributor and yes God only knows why
Old Jun 1, 2022 | 06:48 AM
Tenderpaw's Avatar
Tenderpaw
Ok, this sent me in the right direction. It appears they are just powering the distributor off of the duraspark harness and it is a stand alone HEI. The old duraspark distributor connector is loose elsewhere and there is a taped bundle of wires going to the HEI that probably includes the old coil wires and the power wire.
Thanks for the tip on what to look for.
Old Jun 2, 2022 | 10:51 AM
manicmechanic007
Post a few pics of what you have when you get a chance
Sounds interesting
They make GM HEI's for just about everything now days
Good luck
Old Jun 2, 2022 | 10:43 PM
Tenderpaw's Avatar
Tenderpaw
Its kind of a hack job
they are powering the electric choke off of the same wire.
Kyle Wood
16
Apr 1, 2017 08:18 AM
Ghostka78
May 1, 2013 09:24 PM
ol'bluef150
23
Mar 25, 2010 10:37 AM
danlee
May 19, 2005 07:20 AM
