Too many error codes
Old May 2, 2024 | 02:47 PM
I.am.mayo's Avatar
I.am.mayo
4th Gear
Driving down the road when our truck went in to limo mode. Originally there were several error codes. I changed the intake manifold, coils, throttle position sensor, cam position sensors. Changed oil. Truck barely starts, runs rough, then dies. Still showing Error codes p2104, 2107, 2110. Any ideas?
Old May 2, 2024 | 02:58 PM
aquanaut20's Avatar
aquanaut20
Changing part before confirming them in error only make diagnosis more difficult..
You guess is now better than mine would be..
Old May 2, 2024 | 03:09 PM
I.am.mayo's Avatar
I.am.mayo
4th Gear
Originally there were about 12 codes. Everything we changed was indicated in one or more of the original codes. But it's still showing p2104, 2107, and 2110.
Old May 2, 2024 | 06:12 PM
aquanaut20's Avatar
aquanaut20
Let me make it abundantly clear, codes are a direction not a definite solution towards throwing any parts at the issue, many times additional problems are initiated by the replacements.
It is important you know the correct function and understand how to properly diagnose, guessing is not the way..
Old May 2, 2024 | 08:54 PM
BossHog39's Avatar
BossHog39
seen some of these codes before check wiring harness that run down back of engine on p side and from PCm running to transmission they had a fault on these trucks the holder that hold harness up on back of engine breaks and the harness falls down onto passenger side Exhaust manifold and burns through the harness and shorts out wires to the manifold I have seen this 3 different times on both the 5.4 06 navigator a 05 f150 and a 07 f150 seems to be in the 04 -08 models the transmission control and can bus & O2 Sensors all run down that harness they cause all kinds of hell and limp mode status. pull p side wheel well and look between firewall and back if engine right above the exhaust manifold you will see that harness and if it is laying on manifold. I would start there since I know this can be a issue on them
Old May 2, 2024 | 11:55 PM
I.am.mayo's Avatar
I.am.mayo
4th Gear
thank you so much
Old May 5, 2024 | 07:35 PM
projectSHO89's Avatar
projectSHO89
The "about 12 codes" usually means a fuse is blown. Usually caused by the issue described by bosshog
Old May 6, 2024 | 02:40 PM
getterdun1's Avatar
getterdun1
This may help:
bounceroo
May 3, 2024 05:25 PM
JB-Morrison
Jul 12, 2022 05:19 PM
Maathiu Ra Yin
Electrical Systems/Wiring
Oct 18, 2016 09:37 AM
tcroson
Apr 1, 2015 05:50 PM
Rag58
1983 - 2012 Ranger & B-Series
Aug 6, 2006 08:45 PM
