Overhead Trip Computer Codes
Old Feb 21, 2024 | 06:34 PM
Excurvelle's Avatar
Excurvelle
I bought a new ELM for ForScan and when testing I an receiving several codes from the Overhead Trip Computer:
Code: P0500 - VSS sensor circuit fault.
Code: U2016 - Overhead Trip Computer Signal Link Circuit Failure
Code: B2148 - PWM Input Circuit Failure
Code: B1255 - External air temperature sensor circuit open
I noticed the trip computer not responding the other day, I reset it and it started to work.
The P0500 could only be to the OTC feed as I have no other symptoms or errors in the other systems.
I have been chasing down a poor A/C performance issue so the B1255 interests me however the EATC has no codes and the temp display is normal. The OTC was replaced years ago under warranty and always reads -40. The unit went dark a few years back and I had it fixed at Circuit Board Medics. Outside ambient sensors are still available from Ford. Part #: DY1137
I am not sure about the B2148 code
I have the dash apart and want to put it back together but I don't want to repeat work if it is an Instrument Cluster.
Any suggestions?
Old Feb 22, 2024 | 09:13 AM
Excurvelle's Avatar
Excurvelle
Called Circuit Board Medics, they say it sounds like the OTC needs attention because all the codes point to it.
Old Feb 22, 2024 | 04:20 PM
bismic's Avatar
bismic
Do they offer services to repair that?
Old Feb 23, 2024 | 06:51 AM
Excurvelle's Avatar
Excurvelle
Yes, they repair the trip computers. I will pull it this weekend and ship it on Monday. The online form has you list all of the issues with an item.
BTW Circuit Board Medics also repairs clusters, certain EATC units, PCMs and FICMs
I am glad to see people are in business now to fix the electronics, as newer vehicles age this will be the death of them, one module can put it in the junk yard.
Old Feb 24, 2024 | 04:38 AM
Fuzzpuss's Avatar
Fuzzpuss
I had my OTC repaired at FICMRepair and the compass still doesn't work. They have a disclaimer on their product page that says they don't guarantee the compass will work following a rebuild. Would be nice to know what Circuit Board Medics has to say about it.
Old Feb 24, 2024 | 06:13 AM
Excurvelle's Avatar
Excurvelle
My compass works now, the main fault I noticed was the trip computer hung and I am getting the communications error codes. I am going to pull it tomorrow and send it off on Monday.
Old Mar 4, 2024 | 04:25 PM
jsm180's Avatar
jsm180
My compass quit and I sent it here off eBay https://www.ebay.com/itm/280789709614 Speedometer Repair Guy
Quick turn around and works like new, for $26.
flysniper
6.7L Power Stroke Diesel
Jun 30, 2021 09:17 AM
Brian Hughes
1997 - 2003 F150
Sep 22, 2015 12:16 PM
shanejackson
1997 - 2003 F150
Mar 28, 2004 11:53 AM
radarsf150
May 31, 2003 11:22 AM
wildjon300ci
Jun 29, 2002 09:53 PM
