Fuel filter light
Old Feb 15, 2024 | 11:17 AM
Gjorgjija's Avatar
Gjorgjija
Fuel filter light
Hi folks,
today I run my 7.3idi Van, and note that FUEL FILTER light goes on while engine running.
What could be cause of this? Does I need to change the filter or I plug out some wire?
Additionaly dash cluster light is not working, but the part where is A/C is working. Does light bulb is blown or maybe some fuse?
br
Old Feb 15, 2024 | 02:34 PM
tjc transport's Avatar
tjc transport
i ain't rite
when the fuel filter light comes on, it is sensing a vacuum in the fuel circuit between filter and injector pump. this is usually caused by a dirty fuel filter, or plugged fuel lines.
Old Feb 15, 2024 | 03:20 PM
Gjorgjija's Avatar
Gjorgjija
How can I solve that? And does is maybe same issue with that when I press shrader valve while engine is running, no fuel goes out and engine imideatly goes off?
Old Feb 15, 2024 | 04:26 PM
Prototypemech's Avatar
Prototypemech
I would venture to guess that your engine driven fuel pump has died and needs to be replaced. The reason the truck is still drivable is because you have a leak-free fuel system and the injector pump has a transfer pump that's sucking the fuel in.
Hook up a fuel pressure tester to the Schrader port while the engine is idling. You should have 4psi. If your engine driven fuel pump died, you'll have zero psi.
Old Feb 15, 2024 | 04:33 PM
Gjorgjija's Avatar
Gjorgjija
I disconnect fuel hose before filter and crank the engine just a pinch. fuel is flowing, so I guess that the lift pump is ok...
Old Feb 15, 2024 | 06:28 PM
Olds64's Avatar
Olds64
If you live in the US you can rent a fuel pressure gauge from your local auto parts store. Here's a cheapie if you have Horrible Freight nearby.
https://www.harborfreight.com/fuel-p...ter-62637.html
Oops, guess not.
Old Feb 16, 2024 | 12:40 AM
Gjorgjija's Avatar
Gjorgjija
Oops, guess not.
Ohhh if I live in US will be lot easier for repairing...
I live in Macedonia, and I can't find even shrader valve locally... 😕
Old Feb 16, 2024 | 07:42 AM
tecgod13's Avatar
tecgod13
Sounds like you need to replace the fuel filter then.
The dash cluster is lit by several small bulbs. It is possible they all died, or a wire got loose, something corroded. I've never tried to reach up underneath to test the lights, but its pretty easy to pull the cluster. Remover dash trim and there are several screws that hold the cluster in place.
Old Feb 16, 2024 | 09:46 AM
Gjorgjija's Avatar
Gjorgjija
My cousin have pressure tester kit, so I will try these days. Can you explane me what I need to do with wires on the photo, as well as what is the purpose of the transparent hose?
Also, what I need to do if the pressure is 1-7psi, and what to do if is 0?
I am thinking all the day how is possible to have that vacuum in the line??? I know that I have air intrusion, because 2 of the returning caps are leaking a little bit, so I today I recieve return kit and will change it, but this with the vacuum messing my brain...
Old Feb 16, 2024 | 11:27 AM
tjc transport
i ain't rite
the wires are for cars with electric fuel pumps to turn them on with key off by jumping pump to battery power.
Old Feb 17, 2024 | 12:43 PM
tecgod13's Avatar
tecgod13
Vacuum is because the injection pump is sucking more fuel than the lift pump is pushing. Reasons for this include a blocked or pinched fuel line, bad lift pump, blocked fuel pickup in the tank, plugged/gelled fuel filter.
I know you said you disconnected the feed line to the filter and fuel came out while cranking, which means the lift pump works (could still be weak, but its pumping)
Have you replaced the fuel filter yet?
Old Feb 17, 2024 | 01:22 PM
Gjorgjija's Avatar
Gjorgjija
I will order next week from RockAuto, shipping from US is expensive and because of that I need to pay customs fee too, but will menage it.
I am praying to be filter because seems easiest to change it instead to chech pump / tank lines etc.
And yes, fuel comes from the hose before filter.
Also I have anti-return valve on the LP to Filter hose, and I don't know does I need and direction too...
Thanks for helping
timrothschild1
Oct 22, 2023 07:50 PM
thegreatwhitefarmer
Sep 7, 2009 04:45 PM
Larry1981
Apr 8, 2008 06:35 AM
sparke454
Nov 1, 2006 10:01 PM
voodoosmooth
Nov 10, 2004 12:57 PM
