filter light troubles
Old Sep 7, 2009 | 12:13 PM
thegreatwhitefarmer's Avatar
thegreatwhitefarmer
ok so i just changed my oil an fuel filter light.. (the light would not go off) an the light is still on... i recently replaced the sensor because it was leaking... but the light is still on.. my friend told me i might need to clean the sediment bowl on the side of my fuel bowl.. any ideas??
Old Sep 7, 2009 | 12:26 PM
Cuda_jim's Avatar
Cuda_jim
Water in Fuel or Plugged Filter light? If you unplug either one the light will go out with no harm.
Just be sure to drain the housing or replace the filter every 5K miles or so.
It's always a good idea to clean out the filter on the side everytime time you replace the main filter.
Old Sep 7, 2009 | 04:45 PM
thegreatwhitefarmer
thanks! ill try that
