Alignment concern with RAM welded to TR
Old Feb 2, 2024 | 07:09 PM
CousinCarl's Avatar
CousinCarl
It's about time for new tread. I have abnormal tire wear that started after awhile back. I did have bad wheel bearing units that have since been replaced and the wear hasn't seemed to worsen.
I am thinking of getting an alignment prior to new shoes to protect the investment but I have welded my hydraulic RAM to my tie rod per the recommendation of West Texas Off Road. I am contemplating the following fork in the road:
- grind the mounting ears off and buy the clamp mount that WTOR now trusts to not slide on the TR
- buy a new tie rod and the clamp
-forego the alignment for now as the wheel feels pretty true and maybe the bad bearings were the cause of my abdormal tire wear (?)
What say you?
Old Feb 2, 2024 | 07:53 PM
RacinJasonWV's Avatar
RacinJasonWV
I’m not familiar with what you’re dealing with. But isn’t toe adjusted here?
Old Feb 2, 2024 | 08:03 PM
CousinCarl's Avatar
CousinCarl
You're right. I'm a ignoramus. The rod itself won't spin. The adjustment sleeve will. Crisis averted. Carry on
Old Feb 2, 2024 | 08:06 PM
Tpayne621's Avatar
Tpayne621
I would reccomend getting a set of offroad toe plate to check toe/set toe with. You take wheels off an bolt them on in place and take measurement in front and back for quick easy way to check and set toe. I've lined up a few that way.
Old Feb 2, 2024 | 08:07 PM
RacinJasonWV
Awesome!
Old Feb 2, 2024 | 08:12 PM
CousinCarl's Avatar
CousinCarl
Well maybe not. The rod length shortening/lengthening might be the reported issue I read about concerning future alignments when welding to the tie rod. The RAM would compress/bump-stop stearing in one direction and overextend to lock in the other. TBD...
Old Feb 2, 2024 | 08:13 PM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
Toe is adjusted with only the adjuster in the right circle and it should be adjusted with the suspension loaded, tires on the ground.
Old Feb 2, 2024 | 08:15 PM
Tpayne621's Avatar
Tpayne621
Originally Posted by CousinCarl
Well maybe not. The rod length shortening/lengthening might be the reported issue I read about concerning future alignments when welding to the tie rod. TBD...
Possible the issue you seen was for 05+ f250? They have different tie rod that has 2 short end sand a long adjusting in the center where you would mojnt the ram. That style would have issues like you were referring to in first post.
Old Feb 2, 2024 | 08:38 PM
akcooper9's Avatar
akcooper9
What say you?
Get the alignment then check the rod. If you need to adjust it, cut and re-weld the ram mount ears. Or get the clamp on. Don't over think this one...
EDIT: found the clamp...for the price. I re-weld. https://the4x4garage.square.site/
Old Feb 2, 2024 | 08:48 PM
CousinCarl's Avatar
CousinCarl
Thanks coop. Sounds easy enough. You're right, steering shouldnt be too restricted to make it home to check and can address afterwards.
Inline66
Sep 9, 2015 07:08 AM
FLATFORD1976
Oct 15, 2009 11:23 PM
kupiec20
Jun 29, 2009 10:15 PM
DeadIssue
Aerostar
Apr 30, 2006 09:19 AM
seymour
Jun 11, 2002 10:58 AM
