DIY Alignment Tool
Old Sep 5, 2015 | 07:59 AM
Inline66's Avatar
Inline66
DIY Alignment Tool
If anybody needs an idea for a simple alignment tool, here's something I threw together yesterday. You just hook a tape measure onto the horizontal piece on either side of the tire, then stretch it across to the other side to measure the toe. It cost about $3 to make, and worked out great.
Old Sep 5, 2015 | 10:17 AM
GLR's Avatar
GLR
Nice, thanks for sharing.
In addition, you can use two pieces of sheet metal with some grease in between, under each tire. This allows the wheel to move easily when adjusting the toe-in.
Unless you happen to have ball bearing turn tables...
Old Sep 5, 2015 | 11:17 AM
LeoJr's Avatar
LeoJr
Fluorescent tubes are surprisingly straight.
I bunjee these to my rear motorscooter tire to align it with the front.
But the 2x4 idea makes it easier to pull a tape...
Old Sep 5, 2015 | 11:00 PM
izzo's Avatar
izzo
That stuff will get you by. But I am an alignment tech, and the measurements it needs to be at to have minimal tire wear, correct camber and caster are so small to get them correct the human eye can't see them.
I wrench for a living, I am on the alignment rack a lot, brakes, ball joints, suspension motor work a quarter of the time. That will get you by in a pinch, but it's worth at least getting a toe set by a shop. caster doesn't wear tires, camber will if its excessive. A little camber or too much caster will cause a drift/pull to one side or the other. Add just a little bit of camber with the toe being just off even two tenths of a degree and you will be replacing tires long before they should be. excessive shoulder wear etc.
Not knocking this at all. Would def do this if I replaced the front end pieces just to get me by for a little bit.
Old Sep 5, 2015 | 11:19 PM
Inline66's Avatar
Inline66
For sure, this is for a basic home alignment. I just finished some front end work and wanted to get it close enough until I find a good shop nearby to do it for real.
Old Sep 7, 2015 | 01:04 AM
tbm3fan's Avatar
tbm3fan
I once took my Polara in for an alignment and gave them the specs I wanted used and not the old manual. Needless to say the tech didn't listen and set in to the incorrect settings. At checkout I handed the copy to the sales person and said you just did a car for free and walked out. So pissed I took it elsewhere the next day and got it set to what I wanted and it took the tech over an hour to do it. The trick is to find a really good shop that can do these older vehicles.
Old Sep 7, 2015 | 07:02 AM
GLR's Avatar
GLR
The trouble is that a lot of the new computerized alignment machines have such a large window on the specs. So if "it's in the green , it's ok"
Old Sep 8, 2015 | 06:21 PM
jack orchard's Avatar
jack orchard
I Could Be Wrong
[QUOTE=LeoJr;15620805]Fluorescent tubes are surprisingly straight.
I am not an expert, but i would think the weight of the truck should be on the front end before it can be aligned properly.,...jack
Old Sep 9, 2015 | 07:08 AM
LeoJr's Avatar
LeoJr
I'm just setting the toe in after swapping in the D60. The toe won't change with ride height changes like the D50 does.
DesertRider
Aug 3, 2021 10:49 AM
jeffreyclay
Aug 13, 2016 10:04 PM
bomberboat
Oct 28, 2008 12:17 AM
Saurian
Iowa Chapter
Mar 6, 2005 11:39 PM
khilger
Mar 9, 2004 09:43 PM
