Adding Factory E-Locker to Open Diff Truck?
Old Jan 17, 2024 | 08:35 PM
gvsu141's Avatar
gvsu141
Has anyone here swapped the OEM e-locker to a truck that came with the open diff from the factory? I have a 2018 6.2 XLT with the "37" axle code 3.73 open diff. I have found many cases where I'm missing the e-locker that I had in my F-150.
I have a few questions:
  • Is the wiring already available to do this?
    • I know I would need the dash switch/selector.
  • Would it be better to swap the whole assembly, or just the gear/locker assembly? Would a e-locker gears be compatible with a non locker axle housing?
    • I could get a whole axle assembly from a salvage yard for ~$1400
    • Parts/bent axle assembly for ~$700/800, with a good e-locker.
    • I would then sell my takeoff parts to recoup some of the cost either way.
  • Activate with ForScan?
Anything else I'm missing?
Old Jan 17, 2024 | 09:22 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Would be a do it yourself deal if you just swap the whole axle, to swap in the diff components into your axle, you'd be best to let a pro install it so the gear backlash and wear pattern would be set correctly.
I would keep searching for a cheaper axle assembly.
Old Jan 18, 2024 | 06:02 AM
Desert Don's Avatar
Desert Don
Since EVERYTHING on these newer trucks operated through the ECM / BCM / CANBUS systems; does Fords E-lockers operate by a constant 12V power soiurce or is it just a momentary pulse to engage / dis-engage it? And is it 12V to operate it? Is the “hot” side switched or is it the ground side that is switched?
Is your truck going to need a reflash in order to get things to work as installed from the factory?
If it is as simple as just running a switched 12V wire to it, then an axle swap is going to be the easiest by far. I have installed take-off e-lock Rubicon axles in Jeeps where I did it this way and bypassed all the factory nanny stuff and it was very simple.
Old Jan 18, 2024 | 07:12 AM
Pugga's Avatar
Pugga
If you're going through that kind of expense, I'd start looking at aftermarket lockers like and ARB or Yukon (I'm sure there are others as well). That would get you away from the factory wiring and Ford computer and you'd likely end up with a stronger system also.
Old Jan 18, 2024 | 07:23 AM
gvsu141's Avatar
gvsu141
That makes sense. I didn't consider this. Axle swap sounds like the easiest option. It's not too bad to do. Sounds like it's pretty much plug and play then, and the wiring is already there? Just need to add the dash switch and enable in forscan?
I found some more axles in the $1,200 range, which include brake rotors and calipers, lines. Lines. Everything. I also found one for $800, but I would need to inspect it to make sure it's straight.
There's also someone local that sells brand new OEM surplus axle assembly for 1,500.
Old Jan 18, 2024 | 07:31 AM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
I had my rear locker hooked up to an upfitter switch.
A lot of the off-roading guys like these axles for the obvious reasons, and just wire up a simple toggle switch.
Old Jan 18, 2024 | 07:34 AM
Desert Don's Avatar
Desert Don
Same process I did when swapping in axles on Jeeps then……except for upfitter switch. I would have to wire in a switch when I did that.
Old Jan 18, 2024 | 07:38 AM
gvsu141's Avatar
gvsu141
I have thought about that. However ARB only shows an air locker, and nothing is shown on Yukon site for my truck.
I prefer an eLocker over an air locker, and I don't really mind the Ford setup. This doesn't get a lot of extreme use, but I have seen a few scenarios where it would nice to have, especially in these Michigan winters.
As for cost, if I sell my old components I would be able to recoup the majority of the cost. If I'm patient and shop around, I could probably be into the whole setup for $500, or even less. Assuming that the wiring is already there for the Ford setup.
Old Jan 18, 2024 | 07:44 AM
'65Ford's Avatar
'65Ford
The one question I have for this idea is what might happen if a fellow forgets to turn it off...at freeway speed or on dry pavement for instance. I think the factory setup disengages the lock above a certain speed.
Old Jan 18, 2024 | 08:43 AM
OX2's Avatar
OX2
If the rear, not much. If the front, you will know about it pretty soon, just in steering feel.
Old Jan 18, 2024 | 09:02 AM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Going straight ahead nothing much would happen, but in a turn the locked rear would cause one tire to start barking as it jumps since it can't turn at a different speed as the other tire.
And, yes, factory locked rear disengages at, I believe, 25 mph.
Old Jan 18, 2024 | 09:27 AM
Desert Don's Avatar
Desert Don
Just about the same as if one forgets to shift out of 4WD on dry pavement at freeway speeds….….truck will surely explode!!!!!!! LOL
Of course it is best not to forget!
Old Jan 18, 2024 | 09:51 AM
Moundainner's Avatar
Moundainner
On my 2012 with a 6.2 I added the factory e-locker and upgraded to 4.30 gears from the 3.73’s. I ended up finding a steal on the factory for E-locker carrier on eBay for $150, made it a no brainer. Wired it with a relay on a switch right by the 4x4 ****.
Bought the factory bulkhead plug on the differential, hardest part was drilling the large ~ 1-1/4” hole for this plug.
Old Jan 18, 2024 | 11:35 AM
OBS460's Avatar
OBS460
Hard to beat a Detroit locker. It will disengage the inside tire around turns but if you mash the gas it will hook em both instantly.
Old Jan 18, 2024 | 03:00 PM
Moundainner
From looking into the factory wiring diagrams on all data, the factory 10.50” sterling e-locker was Pulse Width Modulated by the transfer case control module to engage and disengage. In order to keep “factory”, replacement of TCCM was required along with the programming.
I bench tested the locker at the PWM 5v signal and it was very weak to engage the locker. Standard switched 12v “felt” like a much more solid engagement. Ran that way for 6 years - 100,000mi on my last truck.
