Adding Factory E-Locker to Open Diff Truck?
Old Jan 18, 2024 | 04:14 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Originally Posted by '65Ford
The one question I have for this idea is what might happen if a fellow forgets to turn it off...at freeway speed or on dry pavement for instance. I think the factory setup disengages the lock above a certain speed.
Common sense. A locked axle is very easy to detect in turns.
Also, being on an upfitter, it would disengage with the ignition just in case you left it on and parked the truck for the night.
Old Jan 18, 2024 | 09:56 PM
Joe T's Avatar
Joe T
If you can run a posi a Trutrac is probably optimal. I would prefer that over the elocker in many ways.
If you run the elocker off a switch you get rid of the 25mph disengagement.
Old Jan 18, 2024 | 10:45 PM
twobelugas's Avatar
twobelugas
But wouldn't it re-engage when your turn the truck back on the next time you drive?
Old Jan 18, 2024 | 11:16 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Yup, sure would.
Old Jan 18, 2024 | 11:22 PM
'65Ford's Avatar
'65Ford
Originally Posted by Ltngdrvr
Going straight ahead nothing much would happen, but in a turn the locked rear would cause one tire to start barking as it jumps since it can't turn at a different speed as the other tire.
And, yes, factory locked rear disengages at, I believe, 25 mph.
Any idea if a heavy load would provide enough traction to make something break? I figure it will depend on how strong of a "lock" it is and that info I can't find. I did a little looking and most folks mention wheel hop/skp but they're empty. I only found one person that broke something by leaving it switched on.
I'm guessing Ford hss some type of nanny protection.
Old Jan 25, 2024 | 01:32 PM
00t444e's Avatar
00t444e
I would go with something much better than the factory e locker like a Yukon Grizzly or Detroit locker.
Old Jan 25, 2024 | 03:09 PM
f250blueoval's Avatar
f250blueoval
The factory E locker takes a lot of abuse off road. Its not a bad locker.
Old Jan 25, 2024 | 03:25 PM
00t444e's Avatar
00t444e
No good on the road though, and it isn't as reliable as an all mechanical locker.
Old Sep 3, 2024 | 03:19 PM
parish8's Avatar
parish8
Originally Posted by gvsu141
Has anyone here swapped the OEM e-locker to a truck that came with the open diff from the factory? I have a 2018 6.2 XLT with the "37" axle code 3.73 open diff. I have found many cases where I'm missing the e-locker that I had in my F-150.
I have a few questions:
  • Is the wiring already available to do this?
    • I know I would need the dash switch/selector.
  • Would it be better to swap the whole assembly, or just the gear/locker assembly? Would a e-locker gears be compatible with a non locker axle housing?
    • I could get a whole axle assembly from a salvage yard for ~$1400
    • Parts/bent axle assembly for ~$700/800, with a good e-locker.
    • I would then sell my takeoff parts to recoup some of the cost either way.
  • Activate with ForScan?
Anything else I'm missing?
did you get this done? i would like to add a factory elocker rear axle to my truck. i can get a complete axle for a reasonable price at the local junk yard. i get stuck in the grass with the way it is now. i am curious if i can get the proper 4wd switch to work(i have a switch now but without the elock part) or even if i can just wire it up externally. either would be fine with me.
Old Sep 3, 2024 | 04:41 PM
NYH1's Avatar
NYH1
Check these out;
Yukon Gear & Axle Dura Grip Positraction Carriers
Powertrax Grip Pro Traction Systems
LOCKERS, POSI's
NYH1.
Old Sep 3, 2024 | 04:50 PM
parish8's Avatar
parish8
that is pretty cheap. i can get the entire rear axle for $600 and install that myself. i am not as confident installing a new carrier.
Old Sep 17, 2024 | 12:41 PM
austinb1017's Avatar
austinb1017
I was devastated my new 2024 order got screwed up and came with an open rear. I couldn't wait to reorder, so ive been researching my options to remedy this. Considering a tru trac, but would really prefer the factory e locker. I was looking under my truck, and the axle has the plug going into the diff for the locker. Do all diffs have the plug now, regardless if open or locking? Or, while I understand it an extreme long shot, could Ford have put a locking axle in my truck and just not the wiring and switch? I realize this is unlikely, however I know locking axles on super dutys are much more common than open. Would be awesome if I just had to wire it to an aux switch.
Old Sep 17, 2024 | 12:48 PM
  #28
WXboy's Avatar
WXboy
I also have an open differential and hate it.
But, I believe e-locker is useless except for specific situations. A far better option is something seamless that is useful ALL the time, such as a Detroit TruTrac or similar. Basically a helical style limited slip is what you want. Those require no switches, wires, air lines, nothing. And they work on pavement, off pavement, foul weather, etc. Just a lot more bang for the buck.
I’m probably going to do a TruTrac in mine when money allows.
Old Sep 17, 2024 | 01:52 PM
  #29
parish8's Avatar
parish8
My truck came with an open rear. I picked up a factory locker at the junk yard for $625. Picked up the dash switch for $50 on eBay. Put them in and plugged them in and as expected they do not work. Next week I am going to try and program the 4wd controller with an elocker truck program. I will report back if that works. If not I will wire it up myself.
Old Sep 17, 2024 | 03:04 PM
  #30
austinb1017
Please do! Im trying not to get my hopes up, but I think my truck may have come with the locking carrier from the factory. The window sticker and door code of course say that it's open. I noticed the axle housing has the plug for the locker though. I then looked and the sticker on the axle itself has the code 3E31. From what I can tell from online research, this means 3.31 electronic locking. I compared to my dad's 2024 with the FX4 package, and the axle codes are identical. I will be ecstatic if I have the locker and just have to wire it up! Even more so if it's relatively simple to add factory function.
