Yes sir it did. I ended up buying the factory harness, switch, and a TCCM from a truck with a locker. The locker works, however I have not been able to figure out the proper forscan changes to get the truck to recognize the TCCM as it should. It works but it gives me a "service 4x4" message on start up. May just stick with it hooked to an AUX switch if I can't figure it out. Not many people have made these changes on a 23+ model yet. My tuck is a 2024 also. I believe on the 17-22 models you can change the TCCM without having to make any additional changes.
I'm trying to do this and have the E locker axle in my truck with the dummy plug.
What harness do I get to plug in the differential and what does it plug into on the truck side?
I am ordering 4x4 control module and switch.
I don't know if I need anything else?
Tim
I will find the part number for the harness and post shortly. You need the harness, switch, and tccm for locking axle. I have done it and the locker works, but still haven’t figured out how to configure the tccm so that I don’t get error messages.
I hooked it up to forscan awhile back, and it had where I could reconfigure modules that were faulting. It's been awhile now so I can't remember exactly, but it was things like the Transmission control module, not specifically the TCCM. I think this could possible fix it, but I was afraid to go through and reprogram those without knowing exactly. I would love to have some more input, as this is the last step to having a factory functioning locker.
Also, I found the part number for the axle harness. PC3T-15K857 It was a very simple install. The harness goes into a connecter right under the bed, so it's just from there down to the axle and the few connections.
You know all you all had to do was buy an Eaton e locker and wire it up to a switch. Why go through all the hassle to further mess with your factory crap computer.
Not true. I checked with anyone who sells differentials and/or lockers and NO ONE makes one because this truck already has lockers in the differential. So, why don't you prove me wrong. I'll give you my VIN and show me the Eaton locker that fits it. Besides, I have $300 into this.
I'm betting you need to rewrite the code to the module worh Forscan
You need a VIN on an identicle truck that has the ELD.
Use motorcraft as built website to find the code you need.
The modules you are looking for are 703-163-01 to 703-163-07
You will likley find only a couple of letters or numbers different on a couple of those lines
Rewrite your new module to match the truck you use for a reference.
You can vins for sale and make sure it's the same model year and trim level.
The newer trucks with electric parking brake have a different harness.
I can make a thread on how to if anybody is interested or PM me.
My truck is 2023 Platinum. I had the E locker differential but it wasn't ordered with like the other guy in here.
Needed switch, harness and AWD module and forscan.
Tim
can you send me the info I need to do this please. My 25 Platinum order showed up with an open diff when I know I ordered the 3.31 licking diff. Thank you
First you need to check your rear differential.
Look for a green "dummy" plug on the backside of your differential.
If you have that then you're half way there.
This gets fairly complicated so you need to be mechanically inclined to a certain degree.
It's not as simple as " send you the information "
You will need to do research to find the part numbers and be versed enough in Forscan to change code in some modules.
I can walk you through how to get it done but you need to do some legwork.
