Brighter headlights
Old Jan 6, 2024 | 12:22 PM
beartracks's Avatar
beartracks
Brighter headlights
I'm in the process of installing the headlight relays and wiring from Wild Horses. Anyone have pics of the wire routing and relay mounting? Original disappears behind the front bulhead and I think I'll have to go infront of the radiator with the relays up by the battery for access.
Old Jan 6, 2024 | 06:13 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Harness goes from dvr headlight plug over to pass headlight plug, then to relay, then battery connection correct? At least that was the routing on my early Bronco using the common headlight upgrade harness. I went in front of the radiator and core support. I also ended up having the relay's and fuse near the battery. Does yours have the option to control low beam (single filament) and then high beam other or BOTH filaments (when on high beam) with a diode?
Did you get this one? https://www.wildhorses4x4.com/produc...Wiring_Harness
This is the one I am talking about, diode controlled dual lights. https://tomsoffroad.com/parts/66-77-...wiring-harness
"NOTE: Our headlight harness includes a pre-installed diode that allows the high and low beams to emit light at the same time when the brights are turned on. Should you need to disable this feature, simply remove the diode from the wiring harness."
Old Jan 6, 2024 | 07:12 PM
Shortbox4x4's Avatar
Shortbox4x4
I installed the WildHorses kit in my 77 F150 around a year ago. I can go out tomorrow morning and take a look how I hooked it all up for you if you want. I don’t remember offhand what I all did but it’s been working like a million bucks and I like the brighter headlights!
Old Jan 6, 2024 | 07:30 PM
tbear853's Avatar
tbear853
I have most of what is needed to just do my own when I catch a chance, warmer weather. I do "have a plan" though. I've decided to fuse the power to low beams separately from the high beams, in case a fuse blows then I have the other.
I did it on a couple vehicles in the past, great results. I'll keep everything across the top of the core support I think, use some split loom wrap. I'll add in a third circuit to use a third relay for my Unity fog lamps.
Old Jan 6, 2024 | 07:46 PM
John89's Avatar
John89
My harness kit was from LMC, but I assume their basically the same.
We removed the grill insert to run the wires over to the passenger headlamp. Use zip ties to hold them in place.
Relays are on back side of radiator core near the battery.
Very happy with our results.
We also installed some ebay sourced LEDs that really light things up.
This is the only picture I could find of our install.
Old Jan 8, 2024 | 09:25 AM
beartracks's Avatar
beartracks
Thanks for the replies. Seems like all my project develop a life of thier own. Wanted to take the grill shell off to replace the nylon nuts that hold on the inserts. Doh!. Looks like I'd have to take the inner fender and the bumper off. Old wiring in the way so I need to pull the battery out and reroute some things. I'm placing the relays and a cicuit breaker next to the battery. Wires to driver side in front of the bulkhead up high. I'll post pics when I get the mess cleaned up a bit.
Old Jan 8, 2024 | 10:12 AM
Viper Pilot's Avatar
Viper Pilot
Similar setup to others.
Mounted on driver’s side core support.
Harness attached to underside of core support with conduit clamps.
Routed to passenger’s side under the hood latch and then through a hole in the core support to the battery.
Old Jan 8, 2024 | 12:24 PM
77&79F250's Avatar
77&79F250
I would NOT separate the outer grill shell from fenders, unless you have to replace either part. All that connected to the core support (from the factory) via the outer grill shell, inner fenderwells and the fenders make for things to fit better... for the most part. If you start taking parts apart, come reassembly time you can start yourself going down the fender to cowl, fender to door, hood alignment/gap chasing road.
Old Jan 8, 2024 | 07:30 PM
maddogjohnson's Avatar
maddogjohnson
I mounted the relays on the front of the core support.
More pics/details here: https://www.ford-trucks.com/forums/1...l#post19666624
I no longer have a voltage regulator because I've since upgraded to a 3g style alternator, but I did have to make sure I worked around the voltage regulator when I originally did the install.
Old Jan 17, 2024 | 01:54 PM
beartracks's Avatar
beartracks
Done. havn't had a chance to drive at night yet.
Old Jan 17, 2024 | 02:03 PM
77&79F250's Avatar
77&79F250
Is that a Flaming River main power quick shut off?
Old Jan 18, 2024 | 08:36 AM
FuzzFace2's Avatar
FuzzFace2
I can tell you you do not want the relays to get wet or they will stop working.
Then you will need to plug in the trucks plugs to have head lights till you can replace the relays.
Dave ----
Old Jan 18, 2024 | 09:39 AM
beartracks's Avatar
beartracks
Yes on flaming river. I have tons of relays under the hood, not had a problem so far.
Old Jan 18, 2024 | 03:26 PM
redroad's Avatar
redroad
These guys "GEP" make a really nice stackable completely waterproof relay fuse box. I used them on my electric fan and headlight upgrade,
jbanna
Dec 26, 2019 09:46 PM
Jpegg01
21
Nov 14, 2017 05:32 AM
ciamcoop
Jan 9, 2017 06:31 PM
'94IDITurbo7.3
Sep 7, 2013 11:57 AM
pctjk
Sep 28, 2007 07:47 AM
