Good morning Oregon and everyone everywhere else. 40 and wet. Rain has stopped for now and there is a hole in the clouds but some nasty looking stuff coming in behind the hole.
Made it home from the Wallowa's. Did something to the passenger side dually's that resulted in a tire with only 29 lbs. air pressure on the morning I was pulling out for home. Got it aired up to 65 and took off in a snowstorm for Enterprise 30 miles away. Stopped at the RV park on the outskirts of Enterprise to clean the holding tanks out and only had 50 psi still in the tire. 15 psi lost in 30 miles is not good for a 430 mile drive. Next stop was Les Schwab Tires. Hole in sidewall. Ended up replacing all 4 tires on the rearend. I had replaced the two front tires a month or so ago. So, 3 hours, 4 tires, $1500 and a Buffaloe Burger later, I was on my way home.
Breakfast time You're late with my breakfast! Active Badger Hole.
