Need help with EBPV...
Old Jun 27, 2024 | 08:48 AM
  #46
Lex2002's Avatar
Lex2002
Maybe Ford Tech Makuloco has better advice:
Old Jun 27, 2024 | 08:52 AM
  #47
FordTruckNoob's Avatar
FordTruckNoob
One way to pinpoint where the leak is coming from is to clean the valley thoroughly and then dust it with talcum powder. Start the engine and then watch carefully for the first sign of oil-stained powder. It may only take a few seconds if the leak is bad.
Old Jun 27, 2024 | 08:56 AM
  #48
Lex2002's Avatar
Lex2002
oh ya wait till my girl sees greasy fingerprints on her talcum powder bottle...are you crazy man?
Jokes aside...if the leak is behind the pedestal how am I going to even get powder back there and then see it.
Old Jun 27, 2024 | 09:17 AM
  #49
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Very carefully is how...
Maybe use a straw to blow some back there. Maybe squeeze the bottle with your clean hands until your cover the target area.
Think outside the box here sir.
Old Jun 27, 2024 | 09:20 AM
  #50
Lex2002's Avatar
Lex2002
yes I know...Im playing with ya. Ive used a camera and just couldn't see with enough clarity. I suppose a little talcum cannot hurt. Thanks for the idea.
Old Jun 27, 2024 | 09:38 AM
  #51
FordTruckNoob
You gotta use Man Powder.
https://www.duluthtrading.com/s/DTC/...a95aeabd09eb64
Old Jun 27, 2024 | 09:51 AM
  #52
Lex2002's Avatar
Lex2002
Am I manly enough to warrant man-powder?
Old Jun 27, 2024 | 10:38 AM
  #53
FordTruckNoob
That’s between you and your shrink.
Old Jun 27, 2024 | 10:59 AM
  #54
Lex2002's Avatar
Lex2002
Johnson's it is!
Old Jun 27, 2024 | 01:25 PM
  #55
udsuth78's Avatar
udsuth78
That is a serious case of baboon ***.
Old Jun 27, 2024 | 03:08 PM
  #56
FordTruckNoob
That statement has so many entendres it ain’t even funny.
Old Jun 27, 2024 | 04:35 PM
  #57
udsuth78's Avatar
udsuth78
Yet I'd likely lay down money that you still laughed.
Old Jun 27, 2024 | 10:13 PM
  #58
FordTruckNoob
Oh ya you betcha I did.
Old Sep 2, 2024 | 01:33 PM
  #59
Lex2002's Avatar
Lex2002
Finally taking the turbo off to install new o rings, Riff Raff Diesel's, Christian approved billet plenum covers and stainless steel braided fuel lines.
Took the boots off that go into the plenum from the spider... Is this little puddle of oil in the boot normal?
Old Sep 2, 2024 | 01:39 PM
  #60
udsuth78's Avatar
udsuth78
Maybe a little excessive but in the ballpark. Do you have oil consumption? If you're going through oil too then you might want to check for signs of leaking at the turbo shaft seals.
