Need help with EBPV...
Old Sep 2, 2024 | 01:47 PM
  #61
Lex2002's Avatar
Lex2002
Originally Posted by udsuth78
Maybe a little excessive but in the ballpark. Do you have oil consumption? If you're going through oil too then you might want to check for signs of leaking at the turbo shaft seals.
Well I rebuilt the turbo center section with a new wheel etc last year. No significant oil consumption but rather a leek down the back of the engine.... Both sides. Am changing the o rings under the new pedestal again too. I must have screwed that up. I used Ford o rings throughout.
Old Sep 2, 2024 | 01:57 PM
  #62
udsuth78's Avatar
udsuth78
If the seals aren't dumping oil then I wouldn't worry. It's just the CCV vapor accumulating. Eventually the intercooler would need cleaned but I'd bet not in our lifetimes.
Old Sep 2, 2024 | 02:18 PM
  #63
Lex2002's Avatar
Lex2002
I hope it's only crank case mist from the pcv system. The turbo seals are new... Hopefully I didn't screw that up. Up lll check the center section for play once I have the turbo out.
Old Sep 2, 2024 | 04:32 PM
  #64
carl2591's Avatar
carl2591
once they are on they are bitch to get off.. it quite the deal..
Originally Posted by Lex2002
Apparently it's been like that for some time .. disconnected.
How does that clip even stay on the arm.. is just friction. If the arm or the flapper linkage connection point got greasy it could slide off...
Old Sep 2, 2024 | 04:43 PM
  #65
carl2591's Avatar
carl2591
when you had the turbo apart did you do the new 360 bearing in turbo.. ?? don't use the ford oring use the o'ring from diesel oring made of viton black and brown.. well i was not able to find them on the site,, not sure what the frick is up..
found it.. https://www.riffraffdiesel.com/turbo-pedestal-o-rings/
Old Sep 2, 2024 | 04:56 PM
  #66
Lex2002's Avatar
Lex2002
I need to disconnect the flexible fuel line to the fuel bowl. Is this the correct tool?
This is the line I need to remove... But on the bowl side... I'm putting on billet plenum covers before I reinstall the turbo... It's been years since I did this
Old Sep 2, 2024 | 05:20 PM
  #67
Lex2002's Avatar
Lex2002
Nevermind....I was looking at the wrong line. That goes into the Hpop not the fuel bowl! Sorry.
Old Sep 2, 2024 | 07:44 PM
  #68
Lex2002's Avatar
Lex2002
I bought the kit from riffraff with the two long bolts and 4 black rings. Fingers crossed.
The block has yellow stains from the OEM rings but I didn't have any luck removing it last time. I don't thing that should make and difference given the sealing surface is the bottom of the turbo not the bottom of the block
Old Sep 2, 2024 | 07:51 PM
  #69
Lex2002's Avatar
Lex2002
Is this a normal amount of play on a shaft?
I rebuilt the turbo last year...
Old Sep 2, 2024 | 08:26 PM
  #70
udsuth78's Avatar
udsuth78
I'm no expert on the turbo department but it looks fine from where I'm sitting.
This has me concerned though. You see the wetness where the exhaust housing mates to the center section, is the just from you flipping it over or does it look like it's been there for a bit?
Old Sep 2, 2024 | 09:26 PM
  #71
udsuth78's Avatar
udsuth78
Just thought @RacinJasonWV might be able to give you a more definitive opinion on your shaft play
Old Sep 3, 2024 | 03:14 AM
  #72
kenn_chan's Avatar
kenn_chan
https://youtube.com/shorts/_n3LH5MU2...17P7dTu5sYyE2C
thats fine and dandy. a turbos issue is almost always thrust bearing related, IE in and out. you can have about .020 of radial play but axial should be less that .008.
Old Sep 3, 2024 | 07:30 AM
  #73
Lex2002's Avatar
Lex2002
...I think it's oil dripping from the mating surface because the unit was on an angle after I set it down.
Old Sep 3, 2024 | 07:32 AM
  #74
Lex2002's Avatar
Lex2002
Thank you so much. That's very good news.
Old Sep 3, 2024 | 07:50 AM
  #75
RacinJasonWV's Avatar
RacinJasonWV
That wetness appears to have came from the sealing surface after the turbo was rolled over judging by the way it’s creeping down from the center of your circle.
Been a while since I’ve been in one but that looks very normal to me. I assume there is no in/out movement?
Yellow stain will probably remain, but should be smooth with no build up of material. The Orings seal on both the turbo and the block.
