Shut off-won't start. Big troubles in litte Copedawgland
#106
#107
I have a CALI model while putting on the new harness and bowl I didn't see any left over wires for connecting or anything...could I be missing something due to being Cali?...
m'm getting nervous now...
#108
Military GenSets are equipped with some equipment saving shutdowns like low oil pressure. During it's start up it overrides low oil pressure for a few seconds then it checks for the pressure...if it's to low it will shut down...What you are saying is the same basic thing...it looks for a sensor reading that should be up to par after the start and run for a few seconds but it's either not there or faulted.
still scratching my head
#109
And the oil levels good in pan and hpop reservoir?
Tin nuts on goot-n-tite?
Checked the icp on the front of the drivers head? They can go bad and let oil seep thru sensor to electronics side.
Also, should be able tonubpkug that sensor and letat run. Engine will set hpop to a preset level.
The following users liked this post:
#110
I replaced ALL sensors...
#111
#112
Thanks for all your help and input!
#114
I think I do have a way to look at LIVE DATA...I'm asking what points I should note when I scan...can you look here?: Cali w/new main harness + bowl runs smooth/ROUGH/smooth - Ford Truck Enthusiasts Forums (ford-trucks.com) Thanks!
and I think PROGRESS is GOOD! Thanks!
What's the opposite of PROgress?
CONgress!
CONgress!
White95PSD
10-04-2022 07:20 PM
95350PS
23
07-01-2013 11:22 AM
towinchebbies
13
02-12-2009 08:18 AM
