Shut off-won't start. Big troubles in litte Copedawgland
#76
I tried pulling straight up and felt like a sissy boy and didn't want to break anything THEN I put a an old screwdriver through the loop and pried down and POPPED it right off...buttoned it back up and the problem still persists with NO tach bounce at all. I'm going to re-terminate the wire on the top end. I tried these plastic clamp things and I don't think they are touching the wires on the engine side...I'll send pics after work when the Sun is up...Thanks!
I'm hoping the slits in the metal are too big to slice in to the actual wire or some other long shot...
Thoughts?
Thanks!
#77
The following 6 users liked this post by 427 fordman:
#78
The following users liked this post:
#79
They were Temporary to see if it worked or not...I agree with 427 above...they are JUNK...I put new connector and wires on the CPS...I would test for continuity but I don't know where the other end of the wires are...I think it may to that big rectangle block of wires next to the under the hood fuses on the fender well. I will go try to twist them together and see what happens...I may have to fill out a police report first...my motivation must have got stolen...even my Dad Jokes are thin...Oh Geeze (Morty Sanchez voice)
#80
#81
No I haven't...I'm at a loss...I may just go ahead and get a whole new harness ...I'm super busy till April...Thanks for checking in though.
I keep going out and just staring at it like I'm going to see something or remember something or something just jump out at me...and nothing...
#82
#83
I got my tax returns and I feel like I'm 10 feet tall!...Right or wrong, I ordered a bunch of new stuff the old girl. The only 2 things I didn't get was a chrome chain welded steering wheel and a chrome barefoot Go-pedal, lol. I got a new wire harness and some other sensors...I want to replace everything the harness plugs in to. Going by memory...on the front there's a coolant sensor ad there's something else between the coolant temp and CPS but I don't know what it is exactly. I also want to remove the shroud and fan...whatever is easiest. I held off on the Valve cover wires...I replaces those a few years/miles ago.
I am going TDY next month so I hope I can work on the truck in April. Fingers crossed!
Thanks Ya'll!
Thanks Ya'll!
#84
I go TDY all the time. It's nice, but also annoying sometimes.
#85
#86
After a little hiatus the time, weather Moon and Sun have all aligned so I started replacing the wire harness. I noticed something right off the bat...the new wire harness was a little different...a couple of wires were missing in the connector's main connection (big square blk by the fuse box under the hood)...hopefully I re-learn how to post pics below, fingers crossed.
ALSO, on the wire harness I found a RELAY? I don't know...it is taped to the harness on top on the HPOP (about there). What is solid state plug in dohicky for? How can I check it and should I get a new one? Like above, I will try to post pics below.
Thanks for following and help scooching me along...
#87
#88
#89
#90
