93 e350 obd1
Old Dec 7, 2023 | 08:24 PM
lynnboy021's Avatar
lynnboy021
Trailering
93 e350 obd1
My check engine light is on my 93 ford e350 7.5 and I connected my obd1 scanner to the ecc test port and I'm getting no readings. I checked all fuses and connections and did not find anything. Am I missing something? Motor starts up fine at idle but when given gas it shacks. It's a rv with 70k miles and don't know much about it besides it had 3 bent pushrods. I check all valves and lifters and they where all fine so I just replaced the bent pushrods and the missing fires stopped. Any way to get this code reader to read codes? It's a blue point obd1/obd2 code reader.
Old Dec 8, 2023 | 08:13 AM
jas88's Avatar
jas88
Try grounding the test lead under the hood and then count the flashes of the CEL to see if there are codes or not.
FX4-350
35
Jan 11, 2014 05:46 PM
Mass20
Dec 15, 2004 11:00 PM
crazandy
Nov 26, 2004 06:55 PM
_GEEZER_
Electrical Systems/Wiring
Apr 11, 2004 12:40 PM
mcastleberg
Aug 13, 2003 04:51 AM
