2015 + Expedition & Navigator 2015 + Ford Expedition and Lincoln Navigator
Auto Start/Stop Issue
Old Dec 4, 2023 | 06:59 PM
nut1605's Avatar
nut1605
My wife has a 2020 Expedition Limited with the auto start/stop feature. Twice in the last week, she will come up to a stop light and the engine will shut off normally. But when the light turns green and she lets off the brake, the truck doesn't restart and she gets a message saying something to the effect of "Put In Park, Press Start Button". What is going on that makes it not want to restart in the auto start/stop mode?
Old Dec 5, 2023 | 07:16 PM
85e150's Avatar
85e150
You are the first to post that particular problem.
The usual issue is AS/S just stops working because the battery is undercharged. The battery management systems in these trucks can't do catch up like older systems, so the battery never gets fully charged. Add poor battery condition and the next thing is no start at all.
You should take it to Ford or someone with a good code reader and see if any codes pop up.
Old Dec 5, 2023 | 07:20 PM
nut1605's Avatar
nut1605
I've got a code reader, I'll hook it up and see if it says anything. I also thought about a battery issue. It showed good voltage but as far as I know it's the original battery (we bought the truck with 10,000 miles on it). If it's not throwing codes, maybe the battery should be swapped. Thanks for the response.
Old Dec 8, 2023 | 03:51 PM
Ford Motor Company's Avatar
Ford Motor Company
Official Ford Pro Rep
Hi there. Feel free to send us a DM with your vehicle's VIN and mileage. We'd be happy to look into this for you.
Old Jan 21, 2024 | 03:18 PM
Lafferty!'s Avatar
Lafferty!
1st Gear
Update?
Any update to this? Today my wife’s truck did this exact same thing! 2021 Expedition Limited, 38,000 miles purchased brand new. Current temp outside is 27 degrees, she came to a stop it turned off and then said to put in park to restart.
Old Jan 23, 2024 | 09:27 AM
nut1605's Avatar
nut1605
I replaced the battery about a month ago. It hasn't happened since. It was intermittent so I can't guarantee that fixed it, but so far so good.
Old Feb 13, 2024 | 08:30 PM
alishasalazar's Avatar
alishasalazar
1st Gear
mine recently started doing this too. 2020 ford expedition. Has never done this before
Old Feb 13, 2024 | 10:12 PM
nut1605's Avatar
nut1605
I replaced the battery and it hasn't done it since.
Old Dec 3, 2024 | 11:24 AM
mpkleinh's Avatar
mpkleinh
1st Gear
Same problem
we have this same issue. Could you advise on how to fix?
Old Dec 3, 2024 | 05:16 PM
nut1605's Avatar
nut1605
Old Jan 25, 2025 | 08:57 AM
Liztrim's Avatar
Liztrim
1st Gear
Me too!
mine just started doing this too. Should I get a new battery? 2020 61k miles, just worrying me to drive alone and have people honking when it stalls
Old Jan 27, 2025 | 06:10 AM
99powerstrokedF250's Avatar
99powerstrokedF250
Sounds like the older ones start doing this instead of just disabling the AS/S system. Considering everyone who has asked hasn't come back and said they still have the issue, I would say yes, replace the battery. Most batteries are only good for 2-3 years anyway, and you've got 4-5 on yours if it's original.
Old Mar 29, 2026 | 01:36 PM
jr32560's Avatar
jr32560
I'm here looking same issue 2018 platinum max my daughter bought its been 3 or 4 times its happened to her
Old Mar 30, 2026 | 07:19 AM
fieldspondlm's Avatar
fieldspondlm
Auto stop start
I have found several models with corrosion on the hood up/open switch at the connector. With corrosion the switch can tell the system the hood is up and it will not restart the vehicle. Also found this to be the case with a Dodge Durango... so I always check this circuit when I have an issue with stop-start function.
Rmack941
2019 - 2023 Ranger
May 13, 2026 04:02 AM
Tncdrew
Jun 29, 2023 03:37 PM
Super Guest
2015 - 2020 F150
Sep 9, 2022 07:37 PM
renoduckman
2021+ F150
48
Dec 28, 2021 04:39 PM
JeffD11n
2015 - 2020 F150
65
Sep 21, 2021 07:34 PM
