Sharing my Excursion
Way Cool!
I’ll probably install the new parking lights this weekend and take pictures.
- Parking light Assembly
- XC3Z 13 201 BA (LFT)
- XC3Z 13 200 BA (RT)
Here is the newly covered wheel and re foamed seat.
Mine needs cosmetic work on the outside now that the interior is nearly done. I plan to re do the front seats (again). My drivers seat lumbar adjuster is shot. It took some searching but I found a new one.
When you do your drivers seat, you might as well do both so they’re both fresh. While you’re at it, the seat bottom foam for the drivers side is still available from Ford. With a small modification you can make a driver side foam work on the passenger side so both seats can have fresh new seat bottom foam. Unfortunately the seat back foam is no longer available. As for new covers, go to a good upholstery shop and have them made from quality leather. It’s not much more and well worth it considering a seat cover supplier is going to use the least expensive material they can. Quality material and superior craftsmanship will pay off in looks and longevity. See where this is going? lol
I’m planning to go this route sometime this year.
The body shop tells me that they have to sand all the way down to the metal, prime, paint, then clear coat both the hood and the rear panel around the third brake light. ~$1400 plus fixing the rust another $2k. This is gonna hurt! 😞
New lumbar adjuster
I'm going to look into that Line-X treatment of the roof - my silver pearl paint is missing in a bunch of spots on the roof, and I like the idea of a permanent protective fix.
I began purchasing the parts to refresh my ac system. I have the dryer, the compressor just arrived and just ordered the Magnetic Disc, Clutch Assy, Pulley and condensor. Currently the ac is blowing a cool 50 deg on an 80 deg day. I would expect closer to 40-45 deg. It may not seem like much but 5 degrees is a lot on a hot day when it's 100+ deg outside. I'll see how much better it is after all the new ac components are installed and it's recharged.
I found a little rust on the very bottom of the passenger side rocker just for of the rear wheel. I took it to two restoration shops and both quoted $1200 to cut fab in new metal, and paint. Add repainting the rear trim piece around the 3rd break light and the hood, another $1100. I'll probably have that done in the next few weeks and post pictures of the finished product.
I found where my rattles and squeaks were coming from after years of headaches. The second row seat, passenger side had an annoying rattle. I found a new seat track and while the seat was at the upholstery shop, they cleaned out all the mechanics. The recline and rolling action work much better and the rattle is gone. The other annoying noise that sounded like someone tapping on the glass has been corrected. After having multiple people help locate the origin I found it almost by accident. The front passenger side door has been gone through tightening everything possible, the second row door, same treatment and even the B pillar has been disassembled more times than I can remember. I was sure it was coming from that area. Then I decided to squirt a little WD40 silicone in the door latch and all of the sudden the noise was no longer.
Now I can drive with a smile from ear to ear. What a joyful experience is is to drive in comfort.
There's more to come and I'll try to post pictures soon so stay tuned!
I want to add that I tried to use a CSF condensor and even though all of their advertising shows it in black, if you order one, it will come in silver. Given that our grills are so large and from the front, you can see the condensor, I wanted it in black. I even ordered it twice. The first I returned because of the color and the second arrived damaged. I thought maybe paint it but two problems there, One is paining it would void it's warranty and second, it was damaged in shipping. These condensers are very fragile. It doesn't take much to damage the fins. I've always favored OEM parts and these OEM condensers are very rare. Fortunately with enough persistence I found one at nearly triple the cost of the CSF.
It was a pleasure to drive the miles this week after all the work and money has been invested in this truck. It's quiet inside, the engine purrs like a kitten and the ride is super smooth as it should be. No rattles or squeaks. With 2 layers of 80 mil Kilmatt everywhere, it was a worth while effort.
I also replaced the front corner lights with new OEM Ford housings and amber led bulbs from VLEDS. I also applied 3M clear paint protection film to the corner lenses. Years ago I added the same to the headlights and they haven't yellowed at all. I also added the same to the third brake light that I wrote about earlier in this thread. The only thing left are the tail lights and I'll get to those sometime later. Now, all the lighting is complete with VLEDS led bulbs everywhere except the headlights are HID from DDM Tuning and two sets of Rigid driving lights. One set has a hyperspot pattern 6 degree spread and the outer are regular spot pattern with an 11 degree spread.
Today at 207K on the clock, Bessie got an oil change and full tank of diesel.
Next on the list is a small amount of rust on the passenger side rocker at the rear wheel well. While at the body shop, the hood and rear spoiler will get re painted. Maybe paint the grill so it looks new again. (pictures of the rust below) Estimates from a couple body restoration shops quoted $1.200. Seems a bit high but this is SoCal where things are a bit higher priced. If they do a good job then I'm happy.
Not much to see but here's a picture where you can see the new a/c compressor and dryer.
More to come so stay tuned!
I am running AGM batteries from Sam's club, not sure if they are the same ones Walmart sells.
I got the first set 4 years ago because they had a decent price and 3 year replacement. At about the 2 year 8 month mark they started giving me issues, went back to Sam's and they replaced both at no cost.
I'm sure I'll be checking out Walmart when I need another set for one of the trucks.
Another thing I discovered is they do oil changes for far less money than anyone else. They even have Rotella diesel oil at the best price. I’ll bring my own OEM oil filter. Hopefully they can change the fuel bowl filter too and I’m set!
I’ll find out in 7K miles.
