No spark problem
Old Apr 28, 2024 | 06:51 PM
Mruysch's Avatar
Mruysch
8th Gear
Might as well give an update. Finally got to looking at it and I cleaned the ignition switch and it is working good now
Old Apr 28, 2024 | 07:49 PM
K9Kodi's Avatar
K9Kodi
while my 81 is a 302, it was given to me bc it would not make spark. i quickly realized i had fuel but yup, no spark. easy nuff, changed ignition module and still no spark, new distributor and i got my spark back. also did a coil and plug wires while at it. could be very simple. not it wasn't just the rotor or cap, apparently there is a pickup or sometbjbt in the distributor itself that was bad, so i replaced the whole unit
Old Aug 27, 2025 | 11:27 AM
Mruysch's Avatar
Mruysch
8th Gear
Thought I would give another update. Did the same thing this spring where it had no spark due to no 12 volts to the coil. Got a new ignition switch and had 12 volts to the coil but still no spark. Got sick of tracing wires and installed an hei distributor and fired right up.
Agj
Oct 21, 2021 11:20 PM
gripnick
Jul 18, 2004 04:14 PM
woodsmaster
Electrical Systems/Wiring
Feb 14, 2004 11:43 AM
SYRacing
Nov 11, 2003 11:21 PM
