1982 302 trook
Old Aug 28, 2025 | 09:53 AM
Valyd's Avatar
Valyd
2nd Gear
1982 302 trook
Got a truck here from a friend after they let some nitwit touch it... it originally had a wiring issue my from understanding, and i think i found that problem, the ignition module run and start wires were crossed at the two point connector, but then for reasons beyond me her friend wired the ignition coil to the voltage regulator and somehow made the truck run like this and they snapped the timing chain(replaced)
the ignition coil still has spark somehow, but the second winding has pretty low resistance(dont know how to accurately read a multimeter)
could it be that this is the wrong module or did it get wired wrong.
Old Aug 28, 2025 | 10:12 AM
JimsRebel's Avatar
JimsRebel
The red and white wires swapping in the connector you are holding is a normal thing, weird but normal.
The truck will run as long as the coil has power to the coil positive.
I your case, someone used the Key ON power from the voltage regulator as a power source for the coil. Are you using a stock round coil with the push ON horseshoe shaped connector?
With your current wiring you are running full voltage to the coil positive, Bypassing the resistor wire.
Jim
Old Aug 28, 2025 | 10:29 AM
Valyd's Avatar
Valyd
2nd Gear
Jim
Yeah its a cylindrical coil that you put two horseshoes on, i completely undid the regulator deal because as far as i am aware a coil doesnt need a constant 12v running to it, plus they had a points condensor attached to the regulator for some reason, and the wires from the regulator, module, and coil were twisted together very sloppily. Right now i am trying to get spark to the hoses and if you say that is normal for the module to cross then my next guess will be the distributor
Old Aug 28, 2025 | 12:14 PM
Max Capacity's Avatar
Max Capacity
You can find the wire diagrams here,
https://www.garysgaragemahal.com/1981-evtm.html
Old Aug 28, 2025 | 12:20 PM
JimsRebel's Avatar
JimsRebel
The condenser/capacitor near the voltage regulator is used as noise suppression for the AM band of the radio, not really needed in the modern world.
Reconnect everything in a stock configuration, ready to run. Turn the key ON.
Check the voltage at the coil positive, it should be around 6-8 volts and the coil should get warm.
This will verify the primary ingition circuit is intact and the ignition module is powered ON.
Jim
gweedo295
18
Jan 10, 2024 05:33 PM
fifty-two_f1
34
Sep 6, 2017 10:03 AM
jshad101
15
Nov 11, 2014 05:50 PM
pageparsley
Electrical Systems/Wiring
Nov 25, 2005 11:04 AM
Z-Burg
13
Apr 13, 2004 07:50 PM
