no coil spark
Old Jul 18, 2004 | 03:56 PM
gripnick's Avatar
gripnick
no coil spark
i have a 1986 f150 6 cylinder. I get no spark from the coil.(already replaced it). This coil is the one used with the ignition module mounted under the distributor.there are two leads in a connector going to the coil.I measure +10 volts on each of these while starting, but no spark from the coil. any ideas?(ignition module maybe?).,....thx...gr
Old Jul 18, 2004 | 04:14 PM
tuxedo's Avatar
tuxedo
The Ignition Module very likely on this type of ignition system.
