No Spark (electrical problem)
Old Feb 10, 2004 | 07:38 PM
woodsmaster's Avatar
woodsmaster
electrical problem
help i have a 78 f250 4wheel drive i plow with thats not getting any spark I have what appears to be 12volts going to the coil ( red&green) and very weak test light reading on the ( green and yellow) side of the coil. should the green and yellow side of coil be 12volts with the key on?
help the snows building up)
Old Feb 10, 2004 | 09:36 PM
Franklin2's Avatar
Franklin2
Try the ignition module mounted on the fender.
Old Feb 11, 2004 | 04:12 AM
woodsmaster
about two mounths ago i had a similar problem the truck would run about 15 minutes then quit,when i changed the ignition module its been fine up until now. recently i changed the coil and ignition switch but still same problem no spark.
Old Feb 12, 2004 | 09:43 PM
Franklin2's Avatar
Franklin2
Some people have problems with aftermarket modules(that's the rumor anyway). I wonder if a Ford module from the junkyard would work?
Old Feb 12, 2004 | 10:54 PM
bob arrington's Avatar
bob arrington
given that many years , it could be the pick up coil in the dizzy ,just replaced my dizzy for $40 bucks , cured it ,bob
Old Feb 13, 2004 | 03:18 AM
woodsmaster
Hey guys i figured it out first i had the module i bought two months ago tested and they said it was no good and gave me a new one . but get this still no spark so i got my buddys old 77 chilton book and started testing wires and low and behold my rotor isnt turning but the cam is. there is wear on the dist. gear so im gona change the gear and see what happens
Old Feb 13, 2004 | 04:51 PM
bob arrington
you can buy the complete dizzy for 40 bucks, then everything will be new,bob
Old Feb 14, 2004 | 05:06 AM
woodsmaster
I bought a complete dizzy as you say, it was $52 here. It didnt do the trick so i tore the front of the engine off all kinds of slack in the timming chain, but the marks are still lined up. either way im gona need a new timing chain so il put the new one in leave the cover off and see if the dist. turns hope its not the cam.
Old Feb 14, 2004 | 11:43 AM
woodsmaster
yep its the cam thanks for the advice
