Smog Pump Replacement Options
Old Nov 20, 2023 | 07:58 AM
Dale95's Avatar
Dale95
So smog pump has been squealing, chirping, etc for about a week. Today I removed the smog pump pulley and used wwhite routing method with a 97 1/8" belt to keep the ol truck up and running. It works but squeals for about 2 seconds on start up, which from what I've read is to be expected.
I would like to either rebuild my smog pump or replace with a rebuilt/new smog pump. I live in a Metro area for now and frequently sit/sleep in the truck with it idling and just generally would like to keep OEM equipment so the next owner doesn't inherit mysteries.
I can't find any replacement pumps except for junkyards and ebay. Ebay wants $300, I haven't asked at junkyards but I'm pretty sure I don't want one anyway. My truck just turned 100k miles last month snd the pump is out so I doubt the junkyard part would last long. If anyone knows where I can buy a new/rebuilt smog pump please spare.
I am thinking maybe I could find a compatible smog pump new for a mustang etc. and then just swap the correct sized pulley over and be good. That's my hope.
Otherwise does anyone have a good write up on how to rebuild the smog pump? Something that will last 30k miles or more.
Thanks in advance!
Old Nov 20, 2023 | 09:36 AM
jas88's Avatar
jas88
The bigger trucks like F250HD and F350 had an idler pulley in place of the air pump which was not required on those trucks.
Old Nov 20, 2023 | 03:24 PM
camper357's Avatar
camper357
Maybe on California trucks with MAF instead of speed density. Otherwise they came with smog pumps.
Old Nov 21, 2023 | 03:28 AM
Soup bean's Avatar
Soup bean
https://www.fullsizebronco.com/threa....507492/page-2
Old Nov 21, 2023 | 04:14 AM
My4Fordtrucks's Avatar
My4Fordtrucks
What truck and engine? I’d take it off if it is pumping smog. The one on my truck pumped air.
Old Nov 21, 2023 | 12:05 PM
manicmechanic007's Avatar
manicmechanic007
None actually pump smog
They all pump air and are just called a smog pumps
Most at the junkyard will be no good due to sitting, the humid air ruins them.
Don't know where to tell you to get a new one but they used to be 125 new from Ford back in the 90s
I would go the Mustang route or whatever is the cheapest for a new one
Old Nov 21, 2023 | 12:14 PM
My4Fordtrucks
I’ve never called them that’s because that isn’t what it is. I would suggest doing what I did and use an idler bracket and pulley. I got mine from LMR but I don’t know if the OP has a 302/351 or something else.
Old Nov 21, 2023 | 12:30 PM
Scndsin's Avatar
Scndsin
I plugged # from my last NPD catalog for the truck you have listed in your info:
https://www.google.com/search?q=F-9A...hrome&ie=UTF-8
mr_malina
Apr 15, 2019 10:18 PM
TexasGuy001
Sep 3, 2018 01:25 PM
Nick bass
Sep 18, 2012 11:00 AM
jblueep
13
Jan 22, 2007 04:41 PM
teflon_80
1978 - 1996 Big Bronco
May 7, 2003 10:37 AM
