Smog Pump Pulley
Old Sep 17, 2006 | 05:49 PM
mr_malina's Avatar
mr_malina
Smog Pump Pulley
I would like to remove my smog pump on my 91 4.9, my only thing is I would like to continue to use the factory belt and routing. Will a mustang delete kit work? Something like this:
http://store.summitracing.com/partde...5&autoview=sku
Any help would be appreciated.
Old Sep 17, 2006 | 06:45 PM
biggreentank's Avatar
biggreentank
Removing the smog pump will give you about 1 HP. It's not worth the trouble.
Old Sep 17, 2006 | 07:15 PM
mr_malina's Avatar
mr_malina
That is not what I am concerned with. I want to clean up the engine compartment and I am cutting off the cats so the smog pump needs to go.
Old Sep 19, 2006 | 03:20 PM
83Van's Avatar
83Van
The pump itself is pretty small, just get rid of all the connected plumbing. With it open on both ends the pump won't sap any more power than a pully, it's free, and you know it will fit.
Old Sep 19, 2006 | 06:27 PM
mr_malina's Avatar
mr_malina
Wont it still be pumping air (making noise)?
Old Sep 19, 2006 | 10:00 PM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
yes, my pump is raising hell now, i took off everything but the pump and its even louder nd its blowing metal chunks out....i have no more cats so theres no use for it....anyone know if the idler pulley thing that fits stangs will work for ours?
Old Sep 19, 2006 | 10:09 PM
mr_malina's Avatar
mr_malina
Thats what I am trying to find out. I might just buy one and find out the hard way.
Old Sep 19, 2006 | 10:36 PM
KubotaOrange76
im thinking of buying one and trying it out too, except they are 80 plus shippig, you cn get a reman pump for 50 bucks
hmmm
im tired of listeneing to mine
Old Sep 20, 2006 | 10:40 AM
mr_malina's Avatar
mr_malina
hmmm
$47
http://store.summitracing.com/partde...0+4294908331+0
$65
Old Sep 20, 2006 | 09:49 PM
KubotaOrange76
i got tired of the noise today, so i pulled the stock pump off(removed alternator, then tookt eh pump pully off so i could get to the top bolt with a socket wrench)....
took the pump apart by removing the 4 bolts on the back, pryed it apart and took the fiberglass blades and metal holders out which gutted the pump, cleaned and repacked the rear bearing and reassembled....selaed the intake and output of the pump with rubber caps.....now my pump is just an idler pully, it doesnt scream anymore and it still usses the stock belt and it cost nothing
Old Sep 20, 2006 | 10:06 PM
mr_malina's Avatar
mr_malina
Thanks for the imput, I might just do that.
Old Sep 20, 2006 | 10:42 PM
KubotaOrange76
to remove te blades without pressing the beringout i had to break them into a few pwices wth a hammer and screwdriver to get them out....you will see once you get her opened up
Old Sep 20, 2006 | 10:54 PM
mr_malina's Avatar
mr_malina
Ok, thanks for the heads up. I wont be doing this for a few weeks anyways.
Old Sep 20, 2006 | 10:58 PM
KubotaOrange76
no problem, let me know if it gos well for you as it did me
Old Apr 15, 2019 | 10:18 PM
KubotaOrange76
for whatever its worth, this worked great until i sold the truck in 2012
4tl8ford
18
Jan 13, 2008 10:09 AM
TheTowingCowboy
19
Oct 23, 2007 08:29 PM
FordF350Baby
Jun 13, 2007 11:38 AM
WA.Ranger
Apr 15, 2006 10:52 AM
mikeyswood
Mar 7, 2006 06:28 PM
