tailgate and camera problems
Old Nov 13, 2023 | 03:13 PM
1dennis3's Avatar
1dennis3
my 2019 F350 6.7 has recently started have a problem with all the cameras and the tailgate latch. None of them work!
It all started at the same time. I have checked and rechecked in Forscan that all cameras are enabled and everything I see is ok, same with the latch,
I had replaced the actuator about 6 weeks ago, and I suspected that maybe it went out again, so I installed a new one, nothing, it still does not release.
When the button is pressed, or the FOB or the button on the dash, nothing happens, no movement or sound from the actuator.
I have traced the wires in the tailgate as far as I can and found nothing wrong.
I've been trying to figure this out for a couple weeks, so I need suggestions.
Old Nov 13, 2023 | 03:49 PM
BC2019F250's Avatar
BC2019F250
Have you checked the plug from the tailgate to the truck?
Old Nov 13, 2023 | 04:59 PM
1dennis3's Avatar
1dennis3
yes, and traced the wires in the tailgate as well as under the truck as far as I could. No loose connectors or worn wires.
Old Nov 13, 2023 | 10:17 PM
mwheue's Avatar
mwheue
Cut and pasted from the manual. Might be worth load testing your batteries.
The electronic tailgate release will not operate when:
• The battery voltage is below the minimum operating voltage.
also have you checked fuses in the battery junction box? Fuse 41 in mine is for the tailgate.. I would also check any fuses for the bcm.
pickerdd
Oct 2, 2025 02:52 PM
Vinford
Feb 10, 2024 06:09 PM
BuiltTough45
Apr 27, 2021 11:42 AM
weez440
Dec 19, 2020 04:36 PM
MooManChu
Jun 12, 2019 11:32 PM
